    UV Mirror H&V
    27 Posts 0 Posters 20.6k Views
      On 25/07/2012 at 19:39, xxxxxxxx wrote:
      When you say you came up with your own function. Do you mean that you are switching layouts, then executing the CallCommands with a function?
      Or are you editing the UV's directly inside of the UVW struct?
      One of the problems I'm having is figuring out how to execute the "Frontal" projection button.
      Frontal (and several other buttons) is not listed in the SDK. And it's not declared in the painter.h file. So AFAIK it can't be called with the CallUVCommand().
      I was hoping the support guys would provide you a solution to making the Mirror V button work. Because that too is a button that is not supported in CallUVCommand. Just like the Frontal button.
      I'm also having an issue getting changed UVW struct vertices to update after I change them.
      But that's a separate issue.
        On 25/07/2012 at 21:39, xxxxxxxx wrote:
        Well i rewrote the function myself, cause i couldn't fix the button problem. So i edit the UVW struct instead.
        The only way to call the functions is to use the callcommand and use its ID which u can look up in the "Customize commands".
        If u want to edit the struct, u need to make sure that your in write mode.
        GetDataAddressR(),i,uvw) <-> GetDataAddressW(),i,uvw);
        ~Dynad
          On 26/07/2012 at 07:47, xxxxxxxx wrote:
          The UV point editing problem I'm having is the UV points don't move. Even when using the W flag.
          Here's the code:
              BaseObject *obj = doc->GetActiveObject();
            if(!obj)return FALSE;
            PointObject *pobj = ToPoint(obj);           //Cast the BaseObject type to a PointObject type and assign it to a variable "pobj"
            Vector *points = pobj->GetPointW();         //Get the array of points in the object(returns their vector positions)
            LONG count = pobj->GetPointCount();
            TempUVHandle *handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);  //Create an instance of the TempUVHandle class
            if (!handle) return FALSE;
            UVWTag *uvwtag = (UVWTag* )(pobj->GetTag(Tuvw, 0));         //The UVW tag that's on the object
            UVWHandle dataptr = uvwtag->GetDataAddressW();             //The array of polygons in the UVWtag
            LONG UVpolycount = handle->GetPolyCount();
            GePrint(LongToString(UVpolycount));
            UVWStruct res;                                             //A struct that we will eventually store the UV values in
            for (LONG i=0; i<UVpolycount; i++)
                LONG polyindx = i;                //Assign the polygon's index# to a variable
                UVWTag::Get(dataptr, i, res);     //Store the polygon UVW info into the variable "res"
                Real ax = res.a.x;                //These are the x,y UV canvas coords. for each point in each UVpolygon(a,b,c,d)
                Real ay = res.a.y;
                ax = 0.5;                         //Move the vertex res.a.x to 0.5 on the canvas
                uvwtag->Set(dataptr,i,res);       //Update the changes to the UVpolygon in the UVW tag <--------Not working!!
                GePrint("ID#: " + LongToString(polyindx));
                GePrint("AX: " + RealToString(ax) +".... " + "AY: " + RealToString(ay));
            FreeActiveUVSet(handle);              //Free the memory
            pobj->Message(MSG_UPDATE);
            EventAdd();
          Everything appears to work correctly. But for some reason the UVW tag won't update to reflect the changes I've made to any of the UV points.
          I thought the Set() function was for setting any UV changes. But it's not working for me. And I don't know why.
            On 26/07/2012 at 08:02, xxxxxxxx wrote:
            I would recommend to change the UVs directly from the UVWTag with UVWTag::GetDataAddressW and UVWTag::Get and UVWTag::Set. This will give you a pointer to the UV array and the individual UV structures. The UVWStruct contains the UVs for the given polygon. Mirror the UV vectors and set the UVs with UVWTag::Set.
              On 26/07/2012 at 08:03, xxxxxxxx wrote:
              Scott, I think you need to send a MSG_UPDATE message to the UVWTag as well.
                On 26/07/2012 at 08:19, xxxxxxxx wrote:
                Thanks for the help Matthias,
                uvwtag->Message(MSG_UPDATE); didn't seem to help.
                I'm not sure how to use UVWTag::GetDataAddressW; like you're suggesting.
                How do I use it so it knows which UWV tag I'm referring to?
                Do I set the tag active active with: SetBit(BIT_ACTIVE);
                Then follow it with:  UVWTag::GetDataAddressW;?
                The UVWTag class is a bit confusing to me trying to use it directly like that.
                  On 26/07/2012 at 08:23, xxxxxxxx wrote:
                  I'll try to come up with an example.
                    On 26/07/2012 at 08:28, xxxxxxxx wrote:
                    That would be very helpful. Thank you.
                    Also.
                    Is there any way at all that we can execute the UV projection buttons (Sphere, Cylinder, Frontal, etc..)?
                      On 26/07/2012 at 08:33, xxxxxxxx wrote:
                      Many of the UV commands are avaible through the CallUVCommand function. This would be an alternative for mirroring as well. It's the way BodyPaint works. I'll try to show this in the example rather than through the UVWTag.
                      So there are several ways to manipulate UVs. In the end it always depends on what you are exactly trying to do.
                        On 26/07/2012 at 09:06, xxxxxxxx wrote:
                        You actually already posted an example how to use CallUVCommand() a while back. And that's where I learned how to use it.
                        But there's a lot of buttons that are not included in it. Like the "Frontal" and "Mirror V"buttons for example. That's why I switched to editing the UV points individually.
                        I'm looking in the C4D_painter.h file. And I don't see these buttons defined in there.
                        And in the C4D_painter.cpp file. The function seems to call to a private class:
                        return C4DOS.Pa->CallUVCommand(padr,PointCount,polys,lPolyCount,uvw,polyselection,pointselection,op,mode,cmdid,settings);
                        Even if the users were smart enough to add new definitions to CallUVCommand(). It seems that we can't access the class that does all the work. But maybe I'm missing something?
                        That's why I was thinking there might be an undocumented way to execute the actual buttons themselves. Something similar to this:
                             LONG tool_id = doc->GetAction();
                             BasePlugin *tool = NULL;
                             tool = FindPlugin(tool_id, PLUGINTYPE_TOOL);
                             if(!tool) return FALSE;
                             DescriptionCommand dc;
                             dc.id = DescID(MDATA_CREATEPOLYGON_BUTTON);
                             tool->Message(MSG_DESCRIPTION_COMMAND, &dc);
                             EventAdd();
                          On 26/07/2012 at 10:54, xxxxxxxx wrote:
                          In case it's useful, here is some code that I cobbled together from some older SDK example code...
                          // FrontalMapUVs() - perform a simple 'frontal' uv-mapping
                          #define SIGDIG    5.0
                          static Real sign(Real n)
                            if( n > 0.0 )    return 1.0;
                            if( n < 0.0 )    return -1.0;
                            return 0.0;
                          static Real TrimDecimal(Real num, Real digits)
                            Real n;
                            n = num * Pow((Real)10.0, digits);
                            n = sign(n) * Abs(Floor(n + 0.5));
                            return n / Pow((Real)10.0, digits);
                          Bool FrontalMapUVs(PolygonObject *op, Matrix mg)
                            if( !op ) return false;
                            LONG numFaces = op->GetPolygonCount();
                            LONG numVerts = op->GetPointCount();
                            Vector *pVerts = op->GetPointW();
                            CPolygon *pPolys = op->GetPolygonW();
                            UVWTag *pUVTag = (UVWTag * )op->MakeVariableTag(Tuvw, numFaces);
                            if( !pUVTag )
                                return false;
                          #ifdef _R12_SDK_
                            UVWHandle    pUVHndl = pUVTag->GetDataAddressW();
                            if( !pUVHndl )
                                return false;
                          #elif _R11p5_SDK_
                            void *pUVHndl = pUVTag->GetDataAddressW();
                            if( !pUVHndl )
                                return false;
                          #else
                            void *pUVHndl = NULL;
                          #endif
                            LONG ndx;
                            Real lenxinv, lenyinv, lenzinv;
                            Vector mapCenter, mapSize, vMin, vMax;
                            vMin.x = 100000.0;
                            vMin.y = 100000.0;
                            vMin.z = 100000.0;
                            vMax.x = -100000.0;
                            vMax.y = -100000.0;
                            vMax.z = -100000.0;
                            for(ndx=0; ndx<numVerts; ndx++)
                                Vector pt = pVerts[ndx] * mg;
                                if( pt.x < vMin.x ) vMin.x = pt.x;
                                if( pt.x > vMax.x ) vMax.x = pt.x;
                                if( pt.y < vMin.y ) vMin.y = pt.y;
                                if( pt.y > vMax.y ) vMax.y = pt.y;
                                if( pt.z < vMin.z ) vMin.z = pt.z;
                                if( pt.z > vMax.z ) vMax.z = pt.z;
                            mapSize.x = Abs(vMax.x - vMin.x);
                            mapSize.y = Abs(vMax.y - vMin.y);
                            mapSize.z = Abs(vMax.z - vMin.z);
                            mapCenter.x = vMin.x+(mapSize.x*0.5);
                            mapCenter.y = vMin.y+(mapSize.y*0.5);
                            mapCenter.z = vMin.z+(mapSize.z*0.5);
                            if (mapSize.x!=0.0) lenxinv = 1.0/mapSize.x;    else lenxinv = 0.0;
                            if (mapSize.y!=0.0) lenyinv = 1.0/mapSize.y;    else lenyinv = 0.0;
                            if (mapSize.z!=0.0) lenzinv = 1.0/mapSize.z;    else lenzinv = 0.0;
                            // Walk the list of polygons and map the UVs
                            for(ndx=0; ndx<numFaces; ndx++)
                                UVWStruct uvw;
                                cmpUVGet(pUVTag, pUVHndl, ndx, uvw);
                                Vector pt_a = (pVerts[pPolys[ndx].a] - mapCenter) + mg.off;
                                Vector pt_b = (pVerts[pPolys[ndx].b] - mapCenter) + mg.off;
                                Vector pt_c = (pVerts[pPolys[ndx].c] - mapCenter) + mg.off;
                                Vector pt_d = (pVerts[pPolys[ndx].d] - mapCenter) + mg.off;
                                uvw.a.x = TrimDecimal((pt_a.x*lenxinv)+0.5, SIGDIG);
                                uvw.a.y = TrimDecimal((-pt_a.y*lenyinv)+0.5, SIGDIG);
                                uvw.b.x = TrimDecimal((pt_b.x*lenxinv)+0.5, SIGDIG);
                                uvw.b.y = TrimDecimal((-pt_b.y*lenyinv)+0.5, SIGDIG);
                                uvw.c.x = TrimDecimal((pt_c.x*lenxinv)+0.5, SIGDIG);
                                uvw.c.y = TrimDecimal((-pt_c.y*lenyinv)+0.5, SIGDIG);
                                uvw.d.x = TrimDecimal((pt_d.x*lenxinv)+0.5, SIGDIG);
                                uvw.d.y = TrimDecimal((-pt_d.y*lenyinv)+0.5, SIGDIG);
                                cmpUVSet(pUVTag, pUVHndl, ndx, uvw);
                            return true;
                          ...note that I call that routine IF the mesh is not already uv-mapped...
                            // start by grabbing the current UVWTag
                            UVWTag *pSrcUVs = (UVWTag* )(op->GetTag(Tuvw, 0));
                            if( !pSrcUVs )
                                // if not already mapped, do a simple frontal mapping
                                if( !FrontalMapUVs(op, op->GetMgn()) )
                                    return NULL;
                          ...also note that I'm just passing the mesh's global matrix, so you could remove that argument and just grab it inside that routine.
                          The only other note is the "cmpUVGet()/cmpUVSet()" calls... those are calls to my version-compatibility routines...
                          // cmpUVGet()
                          void cmpUVGet(UVWTag *pUVWTag, UVWHandle pUVHndl, LONG ndx, UVWStruct& uvw)
                          #ifdef _R11p5_SDK_
                            if( pUVWTag && pUVHndl )    pUVWTag->Get(pUVHndl, ndx, uvw);
                          #else
                            if( pUVWTag )                uvw = pUVWTag->Get(ndx);
                          #endif
                          // cmpUVSet()
                          void cmpUVSet(UVWTag *pUVWTag, UVWHandle pUVHndl, LONG ndx, const UVWStruct& uvw)
                          #ifdef _R11p5_SDK_
                            if( pUVWTag && pUVHndl )    pUVWTag->Set(pUVHndl, ndx, uvw);
                          #else
                            if( pUVWTag )                pUVWTag->Set(ndx, uvw);
                          #endif
                          ...where my _Rxx_SDK_ defines are cumulative (ie. R11.5 is also defined in my R12 (and later) builds and R11.5 and R12 defines are also defined in my R13 (and later) builds, along with the R13 define, etc.).   This is a carry-over from long, long ago... I'm in the process of changing over to a "#if API_VERSION < 13000" type system.
                            On 26/07/2012 at 11:23, xxxxxxxx wrote:
                            Thanks Giblet.
                            That might come in handy later on. But right now I can't even manage to make simple UV point move where I want it to go.
                            I can give them new positions. And those new positions show up as being changed in the console.
                            But they won't budge on the UV canvas. And I don't know why.
                              On 26/07/2012 at 11:25, xxxxxxxx wrote:
                              Just do...
                                pPolyObj->Message(MSG_UPDATE);
                                EventAdd();
                              ...after changing anything on pPolyObj (including any UVWTag modifications).  EDIT: that is... after doing all your changes (you only need to do it once, before returning from your plugin code).
                                On 26/07/2012 at 11:35, xxxxxxxx wrote:
                                Yeah. I tried that (see the code example I posted earlier).
                                It's not working.
                                  On 26/07/2012 at 11:57, xxxxxxxx wrote:
                                  Scott, from where do you call your UV code, e.g. what kind of plugin (tag, command etc.)?
                                    On 26/07/2012 at 12:09, xxxxxxxx wrote:
                                    I'm doing it from a GeDialog plugin. Inside of the Command() method.
                                    We are allowed to edit the existing UV's in existing uvwtags right?
                                    I see lots of MakeTag type UV code in the forums. But not much that deals with editing existing uvwtags.
                                      On 26/07/2012 at 13:01, xxxxxxxx wrote:
                                      The problem is that you are NOT modifying the uvw struct before you Set() it back - you are only modifying (and printing) a local variable. 🙂
                                      EDIT: In other words...
                                      Your comments above are incorrect... modifying the local 'ax' variable is not the same as modifying res.a.x
                                      To fix it, you'd need to...
                                                  **res.a.x** = 0.5;                     //Move the vertex res.a.x to 0.5 on the canvas
                                                uvwtag->Set(dataptr,i,res);       //Update the changes to the UVpolygon in the UVW tag <--------It works!!
                                      Cheers.
                                        On 26/07/2012 at 13:29, xxxxxxxx wrote:
                                        ..just another comment/suggestion...
                                        If you're going to be calling Get()/Set() on the UVWTag (and/or looping through all the uv-polys), then you typically don't need to do the GetActiveUVSet() stuff... that's mostly useful when you need to know which uv-polys/points are currently selected or if you want to work with the arrays directly (uvhandle->GetUVW() / uvhandle->SetUVW()).
                                        The reason it's needed for 'selected uv-points', for example is that... there are basically 4 uv-points per uv-polygon - which may be a far different number (and different indexing) than the total number of points/vertices of the mesh (a cube has 8 vertices, but it has 6 * 4 = 24 uv-points).
                                          On 26/07/2012 at 16:08, xxxxxxxx wrote:
                                          Ah ha.
                                          Now I think I see what I'm doing wrong. I was assigning variables incorrectly.
                                          Here's a working version of my previous example:
                                            BaseContainer bc;                                                //Create an empty container..We'll use this to change some UV attributes
                                            UVWHandle UVpolys = uvwtag->GetDataAddressW();             //The array of polygons in the UVWtag
                                            LONG UVpolycount = handle->GetPolyCount();                 //The number of UVpolygons
                                            UVWStruct res;                                             //An empty struct that we will eventually store the UV values in
        //To access the points in the UV polygons. Use res.a, res.b, res.c, res.d
                                              uvwtag->Get(UVpolys,i,res);                     //Store the polygon UVW info into the variable "res" for each UVpolygon
                                              //UVWTag::Get(UVpolys, i, res);                 //Alternative way to do the same thing
                                              res.a.x = 0.5;                                  //Move the vertex res.a.x to 0.5 on the canvas
                                              uvwtag->Set(UVpolys,i,res);                     //Update the changes to the UVpolygon in the UVW tag
                                              GePrint("AX: " + RealToString(res.a.x) +".... " + "AY: " + RealToString(res.a.y));
                                              GePrint("BX: " + RealToString(res.b.x) +".... " + "BY: " + RealToString(res.b.y));
                                            EventAdd();
                                          Now all I need is a way to execute those UV projection buttons.
                                          If it's even possible.
                                          Thanks a lot Giblet,
                                            On 27/07/2012 at 05:14, xxxxxxxx wrote:
                                            Seems like the only open problem are the UV projection buttons. Btw. I was wrong about CallUVCommand and UV projections. I can't find a way to call them through the API. It looks like you need to do on your own. There is some example code about projections in the TexData structure documentation.
                                            If I've find a simpler way I will get back to it.
