    GetAllTextures() Changed in R12&R13
    2 Posts 0 Posters 252 Views
      On 16/07/2012 at 11:45, xxxxxxxx wrote:
      Cinema 4D Version:   12
      GetAllTextures() now requires pointing to an array. So now the code examples posted in the archives no longer works for me.
      I can't get any textures to return from it using the old code:
          AutoAlloc<AtomArray> myArray;             //Create a new empty atom type array
        if(myArray)
          doc->GetActiveObjects(*myArray,FALSE); //Get any active objects and store them in the array (use GETACTIVEOBJECTFLAGS_0 for R13)
          LONG cnt = myArray->GetCount();        //Returns the size of the array based on how many objects are selected
          for(LONG i = 0L; i != cnt; ++i)
            String name = static_cast<BaseObject*>(myArray->GetIndex(i))->GetName(); //Get the name of each selected object
            GePrint(name);
        ////// Great..Everything is working properly so far ///////
        ////// Now lets check to see what textures are assigned to the selected objects ////////
         BaseContainer bc = doc->GetAllTextures(myArray);  //Create a container pointing to the array of selected objects
         BrowseContainer browse(&bc);                      //Create an instance of the BrowseContainer class
         LONG cid;
         GeData *data;
         while(browse.GetNext(&cid, &data))
             GePrint("found a texture");                 //<---I get nothing in the console...Even with this!?
             Filename fn = data->GetFilename();
             GePrint("Texture: " + fn.GetString());
      Could someone please post a working example of GetAllTextures() that works with R12 and/or R13?
        On 17/07/2012 at 14:22, xxxxxxxx wrote:
        I finally figured out how to make it work.
        This code gets all the textures in the scene. And prints the names of any selected objects:
          if(myArray)
            BaseContainer bc = doc->GetAllTextures(myArray);       //Fill a new container with all the texures in the document
            LONG counter = 0;
            while(bc.GetIndexId(counter) != NOTOK)                 //Get all of the non-empty container items
              counter++;
              Filename fn = bc.GetFilename(counter,NULL);          //Get each container item that is a Filename type
              GePrint(fn.GetString());
            doc->GetActiveObjects(*myArray,FALSE);                 //Get any active objects and store them in the array(use GETACTIVEOBJECTFLAGS_0 for R13++)
            LONG objcnt = myArray->GetCount();                     //Get the size of the array based on how nay objects are selected
            for(LONG i = 0L; i<objcnt; ++i)
              String name = static_cast<BaseObject*>(myArray->GetIndex(i))->GetName(); //Get the names of the selected objects
              GePrint(name);
