    Spline points - local / global
    2 Posts 0 Posters 358 Views
      On 10/07/2012 at 02:43, xxxxxxxx wrote:
      I'm trying to crate a spline, however, I seem to mess up local / global positions.
      Here is what I do.
      I have three Null objects and their global positions.
      Now the spline should start at p1 and end at the middle between p2 en p3 (=(p2+p3)/2).
      I create a spline, calculate the step per frame (midstep = midpoint* (frame/20.0) + p1).
      Everything is ok, when p1 is at 0,0,0. If not, it fails.
      Any ideas?
      Here is the source.
        pass  #put in your code here
      op1 = doc.SearchObject("p1")
        p1 = op1.GetMg().off
        op2 = doc.SearchObject("p2")
        p2 = op2.GetMg().off
        op3 = doc.SearchObject("p3")
        p3 = op3.GetMg().off
        midpoint = (p3 + p2) / 2
        #print midpoint
      frame = doc.GetTime().GetFrame(doc.GetFps())
        if ((frame == 1) and (doc.SearchObject("EigenSpline") == None)) :
            print "Create Spline."
            splineobj = c4d.BaseObject(c4d.Ospline) # Create new spline
            splineobj[c4d.ID_BASELIST_NAME] = "EigenSpline"
            doc.InsertObject(splineobj)
      current = splineobj.GetPointCount()
            splineobj.ResizeObject(1)
            splineobj.SetPoint(0, p1)
      splineobj.Message (c4d.MSG_UPDATE)    #update spline in viewport
            if (frame > 1) :
                splineobj = doc.SearchObject("EigenSpline")
      splineobj.ResizeObject(frame)     #add point
                splineobj.SetPoint(frame-1, midstep)
        On 10/07/2012 at 03:58, xxxxxxxx wrote:
        Solved. The algorithm was wrong, also to difficult.
        It should be: midstep = (midpoint - p1) * (frame/20.0) + p1
