    MultiLineEditText will not scale to window
    2 Posts 0 Posters 564 Views
      On 29/06/2012 at 09:01, xxxxxxxx wrote:
      Cinema 4D Version:   All
      Language(s) :
      I don't know if I'm doing something wrong.
      But I cannot make the MultiLineEdit textbox scale with the window.
      When I create the code in res edit it works fine.
      But when I use the files that res edit generates in C4D R12 or R13. It no loner works.😠
      Since my plugin is a GeDialog type of plugin. I thought perhaps the dialog type plugins don't support the .res file code for this particular behavior.
      So I also tried using the AddMultiLineEditText() function in the CreateLayout() method. And it doesn't work there either: -BFH_SCALE     <-----Doesn't Work ``-BFV_SCALE     <-----Doesn't Work
      -BFH_SCALEFIT  <-----Doesn't Work
      -BFV_SCALEFIT  <-----Doesn't Work
      It's very important to the way my plugin works that MultiLineEdit textbox shrinks and grows with the window. But nothing I do makes it work.
      It appears to be either a bug. Or an undocumented MultiLineEdit textbox limitation.
        On 02/07/2012 at 01:24, xxxxxxxx wrote:
        MultiLineEditText should scale with the window if you set the appropriate flags. Here's an example using  AddMultiLineEditText:
        from c4d.gui import GeDialog
        class TestDialog(GeDialog) :
            def CreateLayout(self) :
                self.SetTitle("MultiLineEditText Scaling")
                self.GroupBegin(id=0, flags=c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, cols=0, rows=1, title="", groupflags=0)
                self.AddMultiLineEditText(1028, flags=c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT)
                self.GroupEnd()
            dialog = TestDialog()
            dialog.Open(dlgtype=c4d.DLG_TYPE_MODAL_RESIZEABLE, pluginid=0, defaultw=600, defaulth=250)
