    DoCommand() not working
    3 Posts 0 Posters 365 Views
      On 16/06/2012 at 13:38, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I'm having problems with the DoCommand() method in my tool plugin.
      All I want to do is use the SendModelingCommand to delete the selected polygon in my tool.
      I select the polygon in my MouseInput() method.
      Then I call to the DoCommand() to execute it and delete the polygon. But it doesn't do anything.
      The MouseInput code :
          BaseContainer state;
        while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the LMB is down
          if (state.GetLong(BFM_INPUT_VALUE) == 0) break; //If the state value is 0. The LMB is no longer down..so don't enter the loop
          LONG x = state.GetLong(BFM_INPUT_X); //Get the cursor's X screen coordinates
          LONG y = state.GetLong(BFM_INPUT_Y); //Get the cursor's Y screen coordinates
          GeShowMouse(MOUSE_POINT_HAND);       //Change the cursor's apperance when the mouse button is down
          //Check if there is a valid poly id, otherwise deselect all polygons
          if(polygonid>-1)
              bs->Select(polygonid);           //Select the polygon that's currently highlighted
              ModelingCommandData mdat;
              BaseContainer bc;
              mdat.bc = &bc;
              DoCommand(mdat);                //Call to the DoCommand and execute it
          else bs->DeselectAll();
      The DoCommand code :
      Bool PolygonTool::DoCommand(ModelingCommandData &mdat)
        BaseObject *op = mdat.doc->GetActiveObject();
        PolygonObject *objPoly=(PolygonObject* )op;
        mdat.mode = MODELINGCOMMANDMODE_POLYGONSELECTION; //Use this for dealing with polygon selections
        mdat.flags = MODELINGCOMMANDFLAGS_CREATEUNDO;
        GePrint("Am I working?");                                                        //This prints fine
        if (!SendModelingCommand(MCOMMAND_DELETE, mdat)) return FALSE;
        GePrint("Am I still working?");                                                 //<-----------Does not print!!
        EventAdd();//Update all the changes
      Notice that after the SendModelingCommand() code. Something bad happens and the last print does not work. I don't know if that has anything to do with the problem or not.
      What am I doing wrong?
        On 17/06/2012 at 08:51, xxxxxxxx wrote:
        You've not set the mdat.doc and mdat.op (at least not with what you have shown for the code).
          On 17/06/2012 at 11:48, xxxxxxxx wrote:
          Thanks Robert.
          That got it working.
