    Pause for user input
    5 Posts 0 Posters 481 Views
      On 13/06/2012 at 11:33, xxxxxxxx wrote:
      Is there a way to have Python pause for user input and then act on that input?
      For example I would like to start a script, press a number, then a comma, then another number and then 'shift' to set the render frame range.  Maybe not the most useful example, but you get the idea.
      Here is a bit of code to look for the shift part, but I still don't know how to capture the number input first:
      # Check for modifier keys
          bc = c4d.BaseContainer()
          if c4d.gui.GetInputState(c4d.BFM_INPUT_KEYBOARD,c4d.BFM_INPUT_CHANNEL,bc) :
              if bc[c4d.BFM_INPUT_QUALIFIER] & c4d.QSHIFT:
                  shiftMod=1
          if shiftMod==1:
      I would also like to start a script, get the current snap settings, let the user create a two point spline, then use that splines point data to print out a distance measure, and finally delete the spline.  This would make a quicker measure tool.
      I'm starting to be fairly proficient at manipulating the data with Python, but am falling short at interactivity with the user.  Anyone?
        On 14/06/2012 at 10:54, xxxxxxxx wrote:
        The Py4D Console in Cinema 4D is only for stdout and does not accept input while running a script. You
        can however use a dialog for this. There are built-in methods that show various dialogs.
        input = c4d.gui.InputDialog()
        I don't know if it's a bug, but you will not be able to recognize when the user clicks 'Cancel' on this
        dialog. Just cancel your script if the user enters nothing.
          if not input:
              c4d.gui.MessageDialog("Script canceled.")
              return # actually only necessary if code follows this if-clause
              c4d.gui.MessageDialog("You've entered: %s" % input)
          On 14/06/2012 at 12:09, xxxxxxxx wrote:
          Thanks Nik.  I have been learning about dialogs today and have run a couple scripts that hung C4D because of no 'cancel' button.  Maybe it's because I'm using R12?  I will be using your 'cancel' code.  Anyways I'm currently struggling with trying to make tabs such as with:
          from c4d import gui
          gui.GeDialog.TagGroupBegin(id=5670,BFH_LEFT[,tabtype=TAB+TABS])
          I know that I'm missing some important code to initialize the tabbed dialog, but since I'm a beginner, I'm not sure what.  Do you suggest looking into the C++ SDK for more info?  Edit:  I'm checking out the SDK now trying to figure out how to translate the C++ code to Python.  Are there any resources for learning to do this that you know of?
            On 15/06/2012 at 07:15, xxxxxxxx wrote:
            Hi visualride,
            What do you mean with "no cancel button"? I guess you are using a Mac? May you post a screenshot of the dialog that does not own a cancel button, please?
            So, you want to make your own dialog?
            There are some examples in the SDK that should at least give you a hint how to use it. There are also various posts on the forum on dialogs. Here is a little example:
            # author: Niklas Rosenstein <[email protected]>
            class InputDialog(c4d.gui.GeDialog) :
              INPUT = 10000
              BTNOK = 10001
              BTNCNCL = 10002
              def __init__(self, title=None, input_text=None) :
                  self.title = title or "User Input"
                  self.input_text = input_text or ""
                  self.result = None
              def CreateLayout(self) :
                  FULLFIT = c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT
                  self.AddEditText(self.INPUT, FULLFIT)
                  self.GroupBegin(0, FULLFIT)
                  self.AddButton(self.BTNOK, FULLFIT, name="OK")
                  self.AddButton(self.BTNCNCL, FULLFIT, name="Cancel")
                  self.GroupEnd()
              def InitValues(self) :
                  self.SetTitle(self.title)
                  self.SetString(self.INPUT, self.input_text)
              def Command(self, id, msg) :
                  if id == self.BTNOK:
                      close = True
                      self.result = self.GetString(self.INPUT)
                  elif id == self.BTNCNCL:
                      close = True
                      self.result = None
                      close = False
                  if close:
                      self.Close()
            def open_input_dialog(default=None, title=None, width=200) :
              dialog = InputDialog(title, default)
              dialog.Open(c4d.DLG_TYPE_MODAL, defaultw=width)
              return dialog.result
              value = open_input_dialog("Enter Text.",
                                        "I'm waiting for your input.")
              if value is None:
                  print "Cancelled."
                  print "Input:", value
              On 15/06/2012 at 15:32, xxxxxxxx wrote:
              Thanks Niklas.  This will be a big help.  I haven't found those snippets of code that I used yesterday that brought up a dialog with the 'cancel' and 'minimize' buttons greyed out, but since it happened more than once I assume it was because of my version (R12) or that the code was written on a PC (I am using a Mac).  If I do come across it again I will post it.
              As I'm learning (I started sporadically about a month ago) I gain many more questions than I answer but it is fun, and hopefully it will even be practical soon.
