    Folding an object in the Object Manager
    8 Posts 0 Posters 566 Views
      On 04/06/2012 at 18:38, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:      Mac OSX  ;
      Language(s) :       PYTHON  ;
      I'm trying to force the folding of an object with children, in the Object Manager.
      I tried it in COFFEE and it didn't work.
      Now I was trying to do it in Python and it seems that it doesn't work either 😞
      I tried with:
      op.SetBit(BIT_OFOLD)
      and with
      op.SetBit(NBIT_OM1_FOLD)
      But nothing happens. Is it also not possible with Python?
      Rui Batista
        On 05/06/2012 at 00:25, xxxxxxxx wrote:
        Have You tried 'GeListNode.ChangeNBit(c4d.NBIT_OM1_FOLD, c4d.NBITCONTROL_SET)' in Python?
        Peter
          On 05/06/2012 at 03:28, xxxxxxxx wrote:
          How should I apply it?
          Like this?
          op.ChangeNBit(c4d.NBIT_OM1_FOLD, c4d.NBITCONTROL_SET)
          If it is, it is still not working 😞
            On 05/06/2012 at 03:54, xxxxxxxx wrote:
            It's necessary to inform the manager about the update with an EventAdd().
            Toggles the fold state:
            op.ChangeNBit(c4d.NBIT_OM1_FOLD, c4d.NBITCONTROL_TOGGLE)
            op.Message(c4d.MSG_CHANGE)
              On 05/06/2012 at 04:21, xxxxxxxx wrote:
              Well, what I'm trying to achieve is an object that folds itself as soon as an object is dropped in or outside it.
              For that, I created a Python Generator with the following code:
              old_childs=0
                  global old_childs
                  childs=0
                  current=op.GetDown()
                  if current is None: return
                  while current is not None:
                      childs=childs+1
                      current=current.GetNext()
                  if childs==old_childs: return
                  old_childs=childs
                  return c4d.BaseObject(c4d.Onull)
              But it is not working. Could it be because the object is trying to fold itself?
                On 05/06/2012 at 05:23, xxxxxxxx wrote:
                A bit confusing, but the clear bit folds the object.
                Example for Python generator:
                  op.ChangeNBit(c4d.NBIT_OM1_FOLD, c4d.NBITCONTROL_CLEAR)
                  return c4d.BaseObject(c4d.Ocube)
                Personally I think it's not a good idea to do and I'm not sure if it's thread safe etc.
                  On 05/06/2012 at 05:37, xxxxxxxx wrote:
                  Weird!! I would assume that to fold we would need to SET the bit.
                  This is for a Vault object - I would place in it objects that I want to keep but that I currently don't need.
                  It will only fold when objects are added or removed from it. But I can still fold/unfold it manually.
                  Thank you very much for your help, Matthias.
                  Rui Batista
                    On 05/06/2012 at 05:57, xxxxxxxx wrote:
                    This should work in an Python Expression Tag.
                    Let me know.
                    Should you need to do this via a Command script,
                    you would need to store the childcount in the parent object
                    itself, using a unique ID from PlugIn Cafe'.
                    Lennart
                    childcountmemo = 0
                        global childcountmemo
                        obj = op.GetObject()
                        obj[c4d.TPYTHON_RESET] = False # Turn off 'Reset on Frame 0'
                        obj[c4d.TPYTHON_FRAME] = False # and 'Frame Dependent'
                        childcount = len(obj.GetChildren())
                        if childcount != childcountmemo and obj.GetNBit(c4d.NBIT_OM1_FOLD) :
                            obj.ChangeNBit(c4d.NBIT_OM1_FOLD,c4d.NBITCONTROL_CLEAR)
                        childcountmemo = childcount
