    Control Cinema through external programm
    5 Posts 0 Posters 459 Views
      On 02/06/2012 at 07:27, xxxxxxxx wrote:
      Hey guys,
      i'm quite new to the topic of c4d-programming and i'm trying to figure out if it is possible to write a plugin/ script that lets me control cinema form a different python and and let these communicate through sockets. So when Cinema starts it should ask the other process why to do. I already saw that its possible to launch code on startup using the startupscript, but cinema doesn't completely start until the script is finished. So I think my code has to be executed as a plugin. Am I right? Is it possible to start a plugin on c4d-startup?? As i said I'm quite new to the topic and this thing is quite trivial. I appreciate your help.
      regards
      Hanso
        On 02/06/2012 at 07:54, xxxxxxxx wrote:
        just to clarify. i think what i want to ask is:
        Is it possible to start a plugin on on c4d-startup and let it do stuff in the background??
          On 02/06/2012 at 08:31, xxxxxxxx wrote:
          Ok just got it to work using c4d.threading.C4DThread. Is this the way to go here??
            On 02/06/2012 at 11:14, xxxxxxxx wrote:
            Hi JohnnyJumper,
            you can either use c4d.threading.C4DThread or use the built-in threading module. Actually, I don't know if there are advantages on using the C4DThread.
            Here's what you could do for example:
            import socket
            import threading
            class MyThread(threading.Thread) :
              def run(self) :
                  client = socket.socket()
                  client.connect(('localhost', 8080))
                  # make stuff with the connection
                  pass
              thread = MyThread()
              thread.start()
            Note that you can not make GUI operations in Cinema 4D from another thread.
            Nik
              On 04/06/2012 at 01:11, xxxxxxxx wrote:
              Thank you Nik,
              threading is better than C4DThread because it works with R12 too. Thanks for the note on Gui operations.
              _
              _
              regards
              Hanso
