    c4d.TEXTURETAG_MATERIAL
    4 Posts 0 Posters 509 Views
      On 23/05/2012 at 23:57, xxxxxxxx wrote:
      Dear Cinema4D Developers,
      In ttexture.h,
      TEXTURETAG_MATERIAL = 1010, // link
      says that TEXTURETAG_MATERIAL takes a link as input. However, how can I implement this requirement using this command-line? I tried with c4d.DA_ALIASLINK but did not work.
      ID_TEXTURETAGMATERIAL=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_MATERIAL,c4d.DA_ALIASLINK,0))
      What I want to do is to assign material " mat1 " to c4d.TEXTURETAG_MATERIAL that way. Is this possible? The entire script is shown below.
      Thank you very much for your kind of help.
      Ricardo.
      from c4d import gui
      def CreateKey(op, id, value, frame) :
      if not op.GetDocument() : raise Exception, "object must be in a document"
      # First check if the track type already exists, otherwise create it...
      track=op.FindCTrack(id)
      if not track:
      	track=c4d.CTrack(op,id)
      	op.InsertTrackSorted(track)
      curve=track.GetCurve()
      key=curve.AddKey(c4d.BaseTime(frame,doc.GetFps()))
      key["key"].SetValue(curve,value)
      fps=30
      frame=180
      doc.SetMaxTime(c4d.BaseTime(frame,fps))
      doc.SetTime(c4d.BaseTime(frame,fps))
      # Materials:
      mat1=c4d.BaseMaterial(c4d.Mmaterial)
      mat1.SetName("MM1")
      mat1[c4d.MATERIAL_COLOR_COLOR]=c4d.Vector(1,1,0)
      doc.InsertMaterial(mat1)
      mat2=c4d.BaseMaterial(c4d.Mmaterial)
      mat2.SetName("MM2")
      mat2[c4d.MATERIAL_COLOR_COLOR]=c4d.Vector(1,0,1)
      doc.InsertMaterial(mat2)
      # Textures:
      mtag=c4d.TextureTag() # Create a new texture tag...
      # Cubes:
      cube=c4d.BaseObject(c4d.Ocube)
      cube.SetName("MyCube")
      cube.InsertTag(mtag)
      doc.InsertObject(cube)
      doc.SetActiveObject(cube) # The record command needs an active object...
      cube.Message(c4d.MSG_UPDATE)
       **ID_TEXTURETAGMATERIAL=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_MATERIAL,c4d.DA_ALIASLINK,0))**
      ID_TEXTURETAGOFFSETX=c4d.DescID(c4d.DescLevel(c4d.TEXTURETAG_OFFSETX,c4d.DTYPE_REAL,0))
      CreateKey(mtag,ID_TEXTURETAGOFFSETX,value=0.50,frame=10)
      CreateKey(mtag,ID_TEXTURETAGOFFSETX,value=0.70,frame=50)
       **CreateKey(mtag,ID_TEXTURETAGMATERIAL,value=mat1,frame=0)**
        On 24/05/2012 at 01:51, xxxxxxxx wrote:
        You can simply assign the material to c4d.TEXTURETAG_MATERIAL like this:
        mtag[c4d.TEXTURETAG_MATERIAL]=mat1
        And CKey.SetValue() only works with float values:
        You should use CKey.SetGeData() instead for the bitmap. I'll ask the developers if it's possible to make this work.
          On 24/05/2012 at 09:59, xxxxxxxx wrote:
          Dear Yannick Puech,
          Thank you very much!
          So, what I have to do is to modify the definition CreateKey by this one:
          def CreateKey(op,id,value,frame) :
          if not track:
           **if type(value)==int or type(value)==float:**
          ** key["key"].SetValue(curve,value)**
          ** else:**
          ** key["key"].SetGeData(curve,value)**
          Isn't it?
          Thank you.
            On 25/05/2012 at 00:37, xxxxxxxx wrote:
            Yes, this should work as expected.
