    Bend deformers
    3 Posts 0 Posters 428 Views
      On 23/05/2012 at 10:17, xxxxxxxx wrote:
      Dear Cinema4D Developers,
      I am having a hard time trying to run the script shown below. The problem is that these two commands are not working at all and I do not know what I am doing wrong:
      CreateKey(bend,ID_DEFORMOBJECTSTRENGTH,value=0.7854,frame=0)
      CreateKey(bend,ID_DEFORMOBJECTSIZE_X,value=400,frame=0)
      Could you help me please?
      Thank you very much!
      Ricardo.
      from c4d import gui
      def CreateKey(op, id, value, frame) :
      if not op.GetDocument() : raise Exception, "object must be in a document"
      #first check if the track type already exists, otherwise create it
      track=op.FindCTrack(id)
      if not track:
      	track=c4d.CTrack(op,id)
      	op.InsertTrackSorted(track)
      curve=track.GetCurve()
      key=curve.AddKey(c4d.BaseTime(frame,doc.GetFps()))
      key["key"].SetValue(curve,value)
      fps=30
      frame=90
      doc.SetMaxTime(c4d.BaseTime(frame,fps))
      doc.SetTime(c4d.BaseTime(frame,fps))
      # Materials:
      mat=c4d.BaseMaterial(c4d.Mmaterial)
      doc.InsertMaterial(mat)
      # Textures:
      mtag=c4d.TextureTag() # Create a new texture tag...
      mtag.SetMaterial(mat) # Link it to our new material...
      # Cubes:
      cube=c4d.BaseObject(c4d.Ocube)
      cube.SetName("MyCube")
      cube.InsertTag(mtag)
      doc.InsertObject(cube)
      # Deformers:
      bend=c4d.BaseObject(c4d.Obend)
      bend.SetName("MyBend")
      doc.InsertObject(bend,cube) # Add it to the Object Manager as a child of the cube...
      # ID DEFINITIONS
      ID_PRIMCUBESUBX=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_SUBX,c4d.DTYPE_LONG,c4d.Ocube))
      ID_PRIMCUBESUBY=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_SUBY,c4d.DTYPE_LONG,c4d.Ocube))
      ID_PRIMCUBESUBZ=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_SUBZ,c4d.DTYPE_LONG,c4d.Ocube))
      ID_PRIMCUBELEN_X=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_LEN,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,0))
      ID_PRIMCUBELEN_Y=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_LEN,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Y,c4d.DTYPE_REAL,0))
      ID_PRIMCUBELEN_Z=c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_LEN,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,0))
      ID_IDBASEOBJECTRELPOSITION_X=c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_REL_POSITION,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,0))
      ID_IDBASEOBJECTRELPOSITION_Y=c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_REL_POSITION,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Y,c4d.DTYPE_REAL,0))
      ID_IDBASEOBJECTRELPOSITION_Z=c4d.DescID(c4d.DescLevel(c4d.ID_BASEOBJECT_REL_POSITION,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,0))
      ID_DEFORMOBJECTSTRENGTH=c4d.DescID(c4d.DescLevel(c4d.DEFORMOBJECT_STRENGTH,c4d.DTYPE_REAL,c4d.Obend))
      ID_DEFORMOBJECTSIZE_X=c4d.DescID(c4d.DescLevel(c4d.DEFORMOBJECT_SIZE,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_X,c4d.DTYPE_REAL,0))
      ID_DEFORMOBJECTSIZE_Y=c4d.DescID(c4d.DescLevel(c4d.DEFORMOBJECT_SIZE,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Y,c4d.DTYPE_REAL,0))
      ID_DEFORMOBJECTSIZE_Z=c4d.DescID(c4d.DescLevel(c4d.DEFORMOBJECT_SIZE,c4d.DTYPE_VECTOR,0),c4d.DescLevel(c4d.VECTOR_Z,c4d.DTYPE_REAL,0))
      doc.SetActiveObject(cube) # the record command needs an active object
      cube.Message(c4d.MSG_UPDATE)
      CreateKey(cube,ID_PRIMCUBESUBZ,value=1,frame=0)
      CreateKey(cube,ID_PRIMCUBESUBZ,value=15,frame=10)
      CreateKey(cube,ID_PRIMCUBELEN_X,value=100,frame=0)
      CreateKey(cube,ID_PRIMCUBELEN_X,value=500,frame=40)
      CreateKey(cube,ID_IDBASEOBJECTRELPOSITION_X,value=105.0,frame=0)
      CreateKey(cube,ID_IDBASEOBJECTRELPOSITION_X,value=50.0,frame=10)
      doc.SetActiveObject(bend) # the record command needs an active object
      bend.Message(c4d.MSG_UPDATE)
      CreateKey(bend,ID_IDBASEOBJECTRELPOSITION_X,value=200,frame=0)
      CreateKey(bend,ID_IDBASEOBJECTRELPOSITION_X,value=700,frame=20)
       **CreateKey(bend,ID_DEFORMOBJECTSTRENGTH,value=0.7854,frame=0)**
      ** CreateKey(bend,ID_DEFORMOBJECTSIZE_X,value=400,frame=0)**
        On 23/05/2012 at 11:17, xxxxxxxx wrote:
        Hello adarpodracir ,
        Welcome to the plugincafe!
        You over-complicate it a little. 🙂 For single-valued Parameters, you can give the ID directly as an
        argument to FindCTrack(). For e.g. vector-fields, you have to specify a DescID.
        track = op.FindCTrack(c4d.LIGHT_BRIGHTNESS)
        descid = c4d.DescID(c4d.DescLevel(c4d.PRIM_CUBE_LEN), c4d.DescLevel(c4d.VECTOR_X))
        track = op.FindCTrack(descid)
        That's basically it. I actually don't know what the t_creator argument should be in the constructor
        of c4d.DescLevel, but it is enclosed in brackets, which means it is optional. And it seems to be the
        cause of the error you get.
        Removing c4d.Obend as argument for t_creator seems to fix the script.
        ID_DEFORMOBJECTSTRENGTH=c4d.DescID(c4d.DescLevel(c4d.DEFORMOBJECT_STRENGTH,c4d.DTYPE_REAL)) # ,c4d.Obend))
        Best,
        -Nik
          On 23/05/2012 at 23:25, xxxxxxxx wrote:
          Thank you very much. Works!
