    SpecialEventAdd()
    7 Posts 0 Posters 588 Views
      On 16/05/2012 at 12:32, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Does anyone have a really, really, simple SpecialEventAdd() example that they can share?
      The example in the docs has too many missing parts that I can't solve.
      For example:
      SpecialEventAdd( MY_PLUGIN_ID, MY_FN_SELECTOR, (VULONG) my_data ); //Which pluginID? The message ID? or the receiving plugin's ID?
      What is MY_FN_SELECTOR controlling?
      what is my_data controlling?
      etc...
      If I had an actual simple working example to look at. I think I can figure out all my questions on my own.
        On 16/05/2012 at 15:50, xxxxxxxx wrote:
        Hi Scott,
        Here's a working example, it's from my render logging plugin and this is the Execute() function of a VideoPostData plugin:
        RENDERRESULT RenderLog::Execute(BaseVideoPost *node, VideoPostStruct *vps)
             BaseContainer bc;
             if(vps->vp != VIDEOPOSTCALL_FRAMESEQUENCE)
                  return RENDERRESULT_OK;
             if(vps->renderflags & RENDERFLAGS_EXTERNAL)
                  if(vps->open)
                       SpecialEventAdd(RL_COMMAND_START);
                  else
                       bc = vps->render->GetRenderData();
                       renderBC = bc.GetClone(COPYFLAGS_0, NULL);
                       SpecialEventAdd(RL_COMMAND_END, 0, (VULONG)renderBC);
        All it does is test if the render is to the picture viewer and if it is, it checks to see if this is the start or end of the render. If it's the start (vps->open is TRUE) then it sends a SpecialEventAdd with no parameters other than the ID. That ID (RL_COMMAND_START) is a unique value, obtained as a plugin ID from this site. It has to be unique so that no other plugin does anything with it. I could have used the videopost plugin's ID, but I needed two IDs so I got two new ones.
        The second message (RL_COMMAND_END) is sent on the end of the render and this time it sends a copy of the render data (the 'renderBC' variable is a class-level pointer to a base container).
        The main plugin listens for these two messages by overriding CoreMessage() and takes action accordingly.
        That should be all you need to get it working.
        Steve
          On 16/05/2012 at 16:54, xxxxxxxx wrote:
          Thanks Steve,
          Could I possibly see how you handle the sent messages in the main plugin's CoreMessage() method?
          Because for some reason I'm not picking up the VideoPostData's SEA message in my dialog's CoreMessage() method.
          Bool myDialog::CoreMessage(LONG id, const BaseContainer& msg)
            if (id == RL_COMMAND_START)                      //If id equals the SEA message
              GePrint("Testing if message is working");      //Print this message<---Not working!
              this->SetString(4002,"Rendering in progress"); //Display this text when rendering<-----Not working!
            return GeDialog::CoreMessage(id, msg);
          I can post the entire .cpp code if needed.
          It's not that long.
            On 17/05/2012 at 01:15, xxxxxxxx wrote:
            Sure. Here's the CoreMessage() function of the dialog which is watching for those messages. You can see there's actually a third message in there, RL_COMMAND_NEWDOC, which is sent by a SceneHook plugin whenever a document is loaded.
            Bool RLDialog::CoreMessage(LONG id, const BaseContainer &msg;)
                 switch(id)
                 case RL_COMMAND_START:
                      // do some stuff
                      break;
                 case RL_COMMAND_END:
                      // do some other stuff
                      break;
                 case RL_COMMAND_NEWDOC:
                      // do some stuff when a document is loaded
                      break;
            As you can see, the method is basically the same as the one you're using, so I don't know why it isn't working for you.
            Steve
              On 17/05/2012 at 07:55, xxxxxxxx wrote:
              Oh Darn.
              I was hoping to see something magical I was missing in your CoreMessage() code that I was doing wrong.
              Obviously I'm doing something wrong. So I'll post my entire .cpp code.
              It's just a simple dialog plugin with a button, checkbox, combobutton, and an editable text field.
              Both plugins are also listed in the main.cpp file. And everything runs without errors....Except the SpecialEventAdd() code doesn't work.
              #include "c4d.h"
              #include "c4d_symbols.h"
              #define DIALOG_ID 1000006   //testing plugin ID for the dialog part of this example
              #define VPOST_ID  1000007   //testing plugin ID for the VideoPostData part of this example
              #define RL_COMMAND_START 1000009     //This is a unique ID number for the SpecialEventAdd() param1
              class MyPostData : public VideoPostData
                    static NodeData *Alloc(void) { return gNew MyPostData; }
                    virtual RENDERRESULT Execute(BaseVideoPost *node, VideoPostStruct *vps);
                    virtual VIDEOPOSTINFO GetRenderInfo(BaseVideoPost *node) { return VIDEOPOSTINFO_0; }
              RENDERRESULT MyPostData::Execute(BaseVideoPost *node, VideoPostStruct *vps)
                 BaseContainer bc;
                 if(vps->vp != VIDEOPOSTCALL_FRAMESEQUENCE) return RENDERRESULT_OK;
                 if(vps->renderflags & RENDERFLAGS_EXTERNAL)    //If the picture view renderer is being used
                   if(vps->open)                                //If it's the start of the rendering process
                     SpecialEventAdd(RL_COMMAND_START);        //Send a SEA message
              Bool RegisterMyPostData(void)
                return RegisterVideoPostPlugin(VPOST_ID,GeLoadString(IDS_POSTDATA),0,MyPostData::Alloc,"",0,0);
              class myDialog : public GeDialog
                private:
                    BitmapButtonCustomGui *myButton;
                    myDialog* dlg;
                    myDialog(void);
                    ~myDialog(void);
                    virtual Bool InitValues(void);
                    virtual Bool Command(LONG id,const BaseContainer &msg);
                    virtual LONG Message(const BaseContainer &msg,BaseContainer &result);
                    virtual Bool GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags);
                    virtual Bool CoreMessage(LONG id, const BaseContainer& msg);
              myDialog::myDialog(void)
              myDialog::~myDialog(void)
                GeFree(dlg);
              Bool myDialog::CreateLayout(void)
                Bool res = TRUE;
                res = LoadDialogResource(IDS_RESDIALOG,NULL,0);  //Loads the external .res file resources
                //This text gizmo we'll create here...not in the .res file
                AddEditText(4002,BFH_SCALEFIT,100,10,0); //id, flags, height, width, password
                return res;
              Bool myDialog::InitValues(void)
                // first call the parent instance
                if (!GeDialog::InitValues()) return FALSE;
                this->SetBool(MY_CHECKBOX,FALSE);           //Sets the checkbox to enabled by default-->looks in the description->c4d_symbols.h file for matching name
                this->SetLong(MY_COMBOBUTTON,FIRST_CHILD);  //Sets the initial button value to the first option in the list-->looks in the description->c4d_symbols.h file for matching name
                this->SetString(4002,"Hello");
              Bool myDialog::Command(LONG id,const BaseContainer &msg)  //This is where the code that does something goes
                BaseDocument *doc = GetActiveDocument(); //Get the active document
                //Set up some actions that will tell c4d that a gizmo has been triggered..We'll used those action variables later on in the switch code block
                LONG myComboButFirst = msg.GetLong(BFM_ACTION_VALUE);    //Assigns an action to a variable
                LONG myComboButSecond = msg.GetLong(BFM_ACTION_VALUE);    //Assigns an action to a variable
                switch (id)
                  case MY_BUTTON:
                        GePrint("Button Was Pressed");
                        break;
                  case MY_CHECKBOX:
                        GePrint("CHKBox was Toggled");
                        break;
                  case MY_COMBOBUTTON:    //This button was created externally in the .res file
                        if(myComboButFirst == FIRST_CHILD) GePrint("First Option Selected");
                        if(myComboButSecond == SECOND_CHILD) GePrint("Second Option Selected");
                        break;
                EventAdd();
              LONG myDialog::Message(const BaseContainer &msg, BaseContainer &result)
              //not used
              return GeDialog::Message(msg,result);
              Bool myDialog::GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags)
                //not used
              class myResDialog : public CommandData // myResDialog is the class name that needs to be listed in the main.cpp file to register it properly
                private:
                    myDialog dlg;
                    virtual Bool Execute(BaseDocument *doc);
                    virtual LONG GetState(BaseDocument *doc);
                    virtual Bool RestoreLayout(void *secret);
              LONG myResDialog::GetState(BaseDocument *doc)
                //Not Used
                return CMD_ENABLED;
              Bool myResDialog::Execute(BaseDocument *doc)
                StopAllThreads();
                return dlg.Open(DLG_TYPE_ASYNC,DIALOG_ID, -1, -1, 300,150);
              Bool myResDialog::RestoreLayout(void *secret)
                return dlg.RestoreLayout(DIALOG_ID,0,secret);
              Bool RegistermyResDialog(void)
                String Help = "C++ Dialog is using external resources(.res)"; //This string appears in the status bar when the user hovers over the plugin name in the menu
                //Register the plugin
                return RegisterCommandPlugin(IDS_RESDIALOG, "C++ SpecialEventAdd Example", 0, AutoBitmap("icon.tif"),Help, gNew myResDialog);
              Hopefully someone can tell me why the SpecialEventAdd() is not working.
              Thanks a lot for your help Steve,
                On 17/05/2012 at 08:08, xxxxxxxx wrote:
                This may be a silly question, but are you inserting the VP into the render settings? Your VideoPostData should be visible in the 'Effect...' list of the render settings dialog. You will have to add it manually or it won't be called and therefore will never send a message. Or, of course, you can do it from code but you aren't doing that as far as I can see on a quick look.
                Steve
                  On 17/05/2012 at 08:36, xxxxxxxx wrote:
                  DOH!
                  Hang my picture on the wall of shame. 😊
                  This is the first video effect code I've written. And I was so focused on the code that I forgot all about having to add video effects from the effects option.
                  The code works fine when the effect is added to the render options.
                  Thanks again Steve.
