    Hide a tag
    7 Posts 0 Posters 710 Views
      On 29/04/2012 at 14:53, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Is it possible to add a tag to an object my make it invisible in the Object Manager?
      For example, may I add a Tcoffeeexpression tag to an object but hide that tag?
      Rui Batista
        On 29/04/2012 at 16:00, xxxxxxxx wrote:
        As far as I know.
        The only way to hide a tag with Coffee is to do it in a tag plugin like this: myTag::DisplayAllowed() { return FALSE; }
          On 29/04/2012 at 16:28, xxxxxxxx wrote:
          Thank you Scott.
          I already knew that one and I already used it in a tag that I created for one of my plugins.
          But what I need is to hide a COFFEE tag.
          I know that some tags are invisible by default. Could that be a bit that is set in the container of the tags?
          Rui Batista
            On 29/04/2012 at 19:59, xxxxxxxx wrote:
            I've never seen anything like that. Not even the C++ SDK.
            The only way I can see how to hide a tag like that is to:
            -Select the object and assign it to a layer
            -Select the tag and assign it to another layer
            -Solo the object's layer & lock the tag's layer
            This is doable with C++ and Python. But I don't know about with Coffee.
            I seem to recall that Coffee had very limited layer support. But that was a while ago and I can't remember.
            Probably not what you're wanting. But it's the only way I know how to hide tags at will like that.
            Maybe someone else will know a better way.
              On 30/04/2012 at 01:41, xxxxxxxx wrote:
              In C++ you can use the PLUGINFLAG_HIDE in the RegisterTagPlugin-Function.
                On 30/04/2012 at 02:40, xxxxxxxx wrote:
                And the method mentioned by Satara is basically 'permanent' since the tag is either visible or hidden for good when the plugin is registered at startup of C4D.
                  On 30/04/2012 at 03:05, xxxxxxxx wrote:
                  So, even if I set the PLUGINFLAG_HIDE with tag->SetBit(PLUGINFLAG_HIDE); it will not make it invisible? 😞
                  Rui Batista
