    TP master system crashes R13 immediately
    5 Posts 0 Posters 337 Views
      On 21/04/2012 at 11:19, xxxxxxxx wrote:
      Cinema 4D Version:   R13.051
      I have no idea what's going on here, but every time I try and get the TP_MasterSystem of a scene, Cinema crashes straight away. This is my code and it's basically taken from the doc as is:
      TP_MasterSystem* TPPartioData::GetTpMasterSystem(BaseDocument* doc)
      	if (!doc) {
      		GePrint("No TP Master found");
      		return NULL;
      BaseSceneHook* hook = doc->FindSceneHook(ID_THINKINGPARTICLES);
      if(!hook || hook->GetType() != ID_THINKINGPARTICLES)
      return NULL;
      TP_MasterSystem *tp = (TP_MasterSystem* )(hook); // this is ok
      tp->NumParticles(); // here it crashes with _any_ tp->.... related call
      GePrint("I made it here"); // sadly, not so
      return static_cast<TP_MasterSystem*>(hook);
      I'm compiling with VS2008 for 64bit.
        On 21/04/2012 at 11:27, xxxxxxxx wrote:
        Ok, I don't really understand why and what it does, but I found this in an old thread and after adding it before the tp calls, it works now?
        if (!CheckLib(ID_THINKINGPARTICLES, LIBOFFSET(C4DLibrary_TPOS, MSYS), reinterpret_cast<C4DLibrary\*\*>(&TPOS)))
        GePrint("Checklib failed");
        return FALSE;
          On 21/04/2012 at 11:31, xxxxxxxx wrote:
          I wonder if you put
          if(!tp) return NULL;
          if that would prevent the crash?
          give it a try and let me know.  🙂
            On 21/04/2012 at 15:01, xxxxxxxx wrote:
            See InitThinkingParticles() in the SDK. You need to call this before TP is used (I'm just repeating the SDK when I say that!). I do it and don't have any problems with getting the TP master system.
            Steve
              On 21/04/2012 at 15:07, xxxxxxxx wrote:
              I totally overlooked that! Thanks Steve
