    Init PRIM_PLANE problem
    2 Posts 0 Posters 319 Views
      On 17/04/2012 at 03:49, xxxxxxxx wrote:
      For some reason this parameter will not initialise
      I want it to initialise to ZY  - not the default XY
      in the build - the same approach sets the parameter correctly
      see below under ...
      1 of 2 ############ just testing stuff.
      2 of 2 ############ just testing stuff.
      import c4d, sys, os
      from c4d import plugins, utils as u, bitmaps, gui,documents, Vector as v
      PLUGIN_ID = 1028416		#unique plugin id from plugincafe.com
      class JSplineObject(plugins.ObjectData) :
      		########################## Init interface and values
      	def Init(self, op) :
      		op.SetName("J Spline Creator")	#op is the generator object
      		doc = documents.GetActiveDocument
      		self.InitAttr(op, float, [c4d.P1])       #Init the values you defined in your res file
      		op[c4d.P1] = 40.0                        #Set a default value for point1
      		self.InitAttr(op, float, [c4d.P2])
      		op[c4d.P2] = 20.0
      		self.InitAttr(op, float, [c4d.P3])
      		op[c4d.P3] = 10.0
      		self.InitAttr(op, float, [c4d.CHAMFER])
      		op[c4d.CHAMFER]= 1.0
      		self.InitAttr(op, bool, [c4d.CHAMFER_FLAT])
      		op[c4d.CHAMFER_FLAT] = False
      		self.InitAttr(op, bool, [c4d.OUTLINE])
      		op[c4d.OUTLINE] = True
      		self.InitAttr(op, float, [c4d.OUTLINE_OFFSET])
      		op[c4d.OUTLINE_OFFSET] = 5.0
      		self.InitAttr(op, bool, [c4d.CHAMFER_BASE])
      		op[c4d.CHAMFER_BASE] = False
      		self.InitAttr(op, bool, [c4d.CHAMFER_TAIL])
      		op[c4d.CHAMFER_TAIL] = False
      ########################### 1 of 2 ############ just testing stuff...
      		op[c4d.PRIM_PLANE] = c4d.PRIM_PLANE_ZY #### NEITHER THIS OR 1 Works??
      		op[c4d.PRIM_REVERSE] = 1 #True
      		op[c4d.SPLINEOBJECT_INTERPOLATION] = c4d.SPLINEOBJECT_INTERPOLATION_SUBDIV
      		op[c4d.SPLINEOBJECT_SUB] = 8 # long?
      		op[c4d.SPLINEOBJECT_ANGLE] = u.Rad(4) # float?
      		op[c4d.SPLINEOBJECT_MAXIMUMLENGTH] = 5 # float?
      ########################### 1 of 2 ############ test to here
      		###################END#### Init interface and values
      		########################## Build
      	def Build(self,op) :
      		p1 = op[c4d.P1]
      		p2 = op[c4d.P2]
      		p3 = op[c4d.P3]
      		chamfer_amount = op[c4d.CHAMFER]
      		chamfer_flat_switch = op[c4d.CHAMFER_FLAT]
      		outline_switch = op[c4d.OUTLINE]
      		outline_offset = op[c4d.OUTLINE_OFFSET]
      		chamfer_base_switch = op[c4d.CHAMFER_BASE]
      		chamfer_tail_switch = op[c4d.CHAMFER_TAIL]
      		############# a few limits
      		if p2 < chamfer_amount :
      			p2 =  chamfer_amount
      			op[c4d.P2] = p2
      		############# a few limits - dont let the tail be bigger than J Height
      		if p3 > p1 :
      			p3 =  p1
      			op[c4d.P3] = p3
      		if p3 < -p1 :
      			p3 =  -p1+ 0.1
      			op[c4d.P3] = p3
      		############# if both swiches off - ignore amount in AM and zero
      		if (chamfer_base_switch == False) and (chamfer_tail_switch == False) :
      			chamfer_amount = 0
      		jspline = c4d.SplineObject(4,c4d.SPLINETYPE_BEZIER)
      		jspline.SetPoint( 0, v(0.0, p1, 0.0))
      		jspline.SetPoint( 1, v(0.0, 0.0, 0.0))
      		jspline.SetPoint( 2, v(-p2, 0.0, 0.0))
      		jspline.SetPoint( 3, v(-p2, p3, 0.0))
      		jspline[c4d.SPLINEOBJECT_CLOSED] = False
      		sel = jspline.GetPointS()
      		sel.DeselectAll()
      		############# select points depending on AM checkbox
      		if chamfer_base_switch == True:
      			sel.Select(1)
      		if chamfer_tail_switch == True:
      			sel.Select(2)
      		############# chamfer the spline
      		bc = c4d.BaseContainer()
      		bc.SetData(c4d.MDATA_SPLINE_CHAMFERFLAT, chamfer_flat_switch )
      		bc.SetData(c4d.MDATA_SPLINE_CHAMFERRADIUS, chamfer_amount)
      		result = u.SendModelingCommand(c4d.ID_MODELING_SPLINE_CHAMFER_TOOL, [jspline],c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc)
      		############# outline the spline
      		if outline_switch == True:
      			bc.SetData(c4d.MDATA_SPLINE_OUTLINE, outline_offset)
      			u.SendModelingCommand(c4d.MCOMMAND_SPLINE_CREATEOUTLINE,[jspline],c4d.MODELINGCOMMANDMODE_ALL,bc)
      ########################### 2 of 2 ############ test testing stuff...
      ########following same logic as above but prim_plane actually works
      		plane = op[c4d.PRIM_PLANE]
      		reverse = op[c4d.PRIM_REVERSE]
      		interp = op[c4d.SPLINEOBJECT_INTERPOLATION]
      		subd = op[c4d.SPLINEOBJECT_SUB]
      		ang = op[c4d.SPLINEOBJECT_ANGLE]
      		maxlen = op[c4d.SPLINEOBJECT_MAXIMUMLENGTH]
      		#### do some processing from  included res Osplineprimitive;
      		#### in this case just print to console to check
      		print 'PLANE: ', plane
      		print 'REVERSE: ', reverse
      		print 'INTERP: ',interp
      		print 'SUBDIV: ', subd
      		print 'ANGLE: ', ang
      		print 'MAXLENGTH: ', maxlen
      		print ' '
      		############# just testing - put the values back????
      		op[c4d.PRIM_PLANE] = plane ##### essentially the same thing as the init WORKS?
      		op[c4d.SPLINEOBJECT_INTERPOLATION] = interp
      		op[c4d.PRIM_REVERSE] = reverse
      		op[c4d.SPLINEOBJECT_SUB] = subd
      		op[c4d.SPLINEOBJECT_ANGLE] = ang
      		op[c4d.SPLINEOBJECT_MAXIMUMLENGTH] = maxlen
      ########################### 2 of 2 ############  test to here
      		return jspline.GetClone()
      	############# Return the built spline
      	############# Go and return the built spline
      	def GetContour(self, op, doc, lod, bt) :
      		return self.Build(op)
          icon = bitmaps.BaseBitmap()
          icon.InitWith(os.path.join(dir, "res", "icon.png"))
          JSplineCreator = plugins.RegisterObjectPlugin(id=PLUGIN_ID, str="JSplineObject",
                                      g=JSplineObject,
                                      description="JSplineObject", icon=icon,
                                      info=c4d.OBJECT_GENERATOR  | c4d.OBJECT_ISSPLINE)
          if JSplineCreator:
          	print 'JSplineCreator Loaded'
        On 17/04/2012 at 08:25, xxxxxxxx wrote:
        Setting PRIM_REVERSE works as expected but PRIM_PLANE not. I contacted the developers on this issue.
