    keyframe an object in conjunction to another
    3 Posts 0 Posters 303 Views
      On 17/04/2012 at 02:41, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:      Mac OSX  ;
      Hi there,
      I have a problem with a script i've been working on. It is supposed to key object B if object A gets keyed using autmatic keyframing. therefore the script listens if at the current frame object A gets keyed and then uses a callcommand(12410) to keyframe object B.
      this works fine if i put the script in the scriptmanager and execute it manualy. but if i put it in a coffeetag so that it should execute automatically, it only works if object A already has had a key on this frame.
      hope that was understandable
      so heres the code:
      main(doc,op)
        if (op == doc->GetActiveObject()){
            var time = doc->GetTime();
            var fps= doc->GetFps();
            var currentFrame = time->GetFrame(fps);
            var track = op->GetFirstCTrack();
            var abordwhile;
            while (track && abordwhile!=true)// iterate through all recorded tracks
                if (track->GetName() == "Position . X" || track->GetName() == "Rotation . H") //only for position and rotation tracks
                    var curve = track->GetCurve(CCURVE_CURVE, FALSE); //Find the curve on a track
                    var keyTotal = curve->GetKeyCount();// count how many keys are on the track
                    var k;
                    for(k=0; k<(keyTotal); k++)// iterating through the keys to find which is on the current frame
                        var keytime = curve->GetKey(k)->GetTime()->GetFrame(fps);// get the frame K is on
                        if (keytime==currentFrame)// if the frame key k is on is the same frame the slider is on
                            k = keyTotal; // set k equal to the total number of keys on the track to stop the iteration through the keys
                            abordwhile = true; // stop iterating through the tracks
                            var Keythis1=doc->FindObject("Keythis"); //get the object, set it active and key it
                            if (Keythis1){
                                doc->SetActiveObject(Keythis1);
                                CallCommand(12410);
                                println("there should be a key now");
                                doc->SetActiveObject(op);
                track = track->GetNext();// go on and do the same thing to the next track until no more tracks are found
      Thanx,
      Bonzo
        On 17/04/2012 at 05:43, xxxxxxxx wrote:
        i guess the callcommand() is colliding ith the editor playback. this is how i would do it in python :
        from c4d import documents
            objA = doc.SearchObject("A")
            objB = doc.SearchObject("B")
            t = doc.GetTime()
            if (objA != None and objB!= None) :
                if hasKey(objA, t, ["Position . X","Rotation . H"]) :
                    setKey(objB, t, ["X-Ray"])
        def hasKey (obj, time, tracknames) :
            for track in obj.GetCTracks() :
                for name in tracknames :
                    if (name == track.GetName()) :
                        if (track.GetCurve().FindKey(time) != None) :
                            print 'Found key on {0}.{1} at {2}'.format(obj.GetName(), name, time.Get())
            return False
        def setKey (obj, time, tracknames) :
                        curve = track.GetCurve()
                        if (curve.FindKey(time) == None) :
                            key = c4d.CKey()
                            key.SetTime(curve, time)
        	            # as i am not sure how your key values are driven, you have to add some logic here
                            key.SetValue(curve, 0)
                            curve.InsertKey(key)
                            print 'Added key on {0}.{1} at {2}'.format(obj.GetName(), name, time.Get())
          On 17/04/2012 at 07:51, xxxxxxxx wrote:
          wow thank you. that is exactly what i was going for. only that yours is working 😉
          seems like i should dive more into python.
          thank you again!
          Bonzo
