    Clashing IDs
    6 Posts 0 Posters 627 Views
      On 16/04/2012 at 02:41, xxxxxxxx wrote:
      OK - I'm still new to this, don't laugh
      My plugin GUI items start at 1000, 1001
      which work fine
      then I added
      INCLUDE Osplineprimitive;
      to my plugin res file
      now changing some of my GUI items  - changes the included interface
      so I changed my own gui enum ID  - that stopped the clash with the Osplineprimitive;
      - now my interface items don't work
      how do the enum IDs connect with your own interface items?
      help!
        On 16/04/2012 at 05:01, xxxxxxxx wrote:
        First, in the Python SDK DoubleCircle's example (it also includes Osplineprimitive) the enum begins at 10000 (same in C++).
        What's not working as expected in the interface ?
          On 16/04/2012 at 05:33, xxxxxxxx wrote:
          Sorry Yannick - I open the PY file mentioned and it says
          enum
          	PYCIRCLEOBJECT_RAD		= 10000 // values 1000.3000 already reserved from includes
          #endif
          fromm that are we to guess that we can't use any IDs from 1000 to 3000
          IF we are going to use the INCLUDE res files in our plugins
            On 20/04/2012 at 04:30, xxxxxxxx wrote:
            Yes, that's true.
            Those IDs are mostly used by the base attributes you automatically get when including something like "Obase" in your .res file.
            If you start your IDs with greater values (like e.g. 10000) you will be on the safe side.
              On 21/04/2012 at 00:46, xxxxxxxx wrote:
              thanks for confirmation
                On 21/04/2012 at 01:51, xxxxxxxx wrote:
                as a side note : obase stays below 1000, only if you include extra standard interfaces like
                ospline you have to make sure which ids above 1000 you are using.
