    Multiple individual chamfers problem
    4 Posts 0 Posters 460 Views
      On 01/04/2012 at 02:27, xxxxxxxx wrote:
      Take a square spline - 4 point
      Its straightforward  to globally chamfer all four points
      or apply the chamfer to a particular point (by selecting it and not others - user data boolean)
      if chamfer_0_switch:  sel.Select(0)
      if chamfer_1_switch: sel.Select(1)
      if chamfer_2_switch:  sel.Select(2)
      if chamfer_3_switch: sel.Select(3)
      but - how do you apply different chamfer radii to individual points
      currently using
      bc.SetData(c4d.MDATA_SPLINE_CHAMFERRADIUS, chamfer0)
              u.SendModelingCommand(c4d.ID_MODELING_SPLINE_CHAMFER_TOOL, [obj],
                       c4d.MODELINGCOMMANDMODE_POINTSELECTION, bc, doc,
                       c4d.MODELINGCOMMANDFLAGS_CREATEUNDO)
      problem being - as soon as you apply the chamfer to a single point
      the point count changes
      tia
        On 01/04/2012 at 02:49, xxxxxxxx wrote:
        simply chamfer point by point ? as long as you are chamfering in ascending/descending point id order
        you won't have any problems with your selection ids. each following selection id is n+1.
          On 01/04/2012 at 03:03, xxxxxxxx wrote:
          ie I need a point count dependent on chamfers selected
            On 02/04/2012 at 01:41, xxxxxxxx wrote:
            yes,
            you could use a struct like approach. however you will have to make sure to chamfer in ascending
            order with this approach.
            class IDRad() :
                def __init__(self, id=None, radius=None) :
                    self.id = id
                    self.radius = radius
                sel = []
                counter = 0
                sel.append(IDRad(0,5))
                sel.append(IDRad(5,2))
                sel.append(IDRad(10,4))
                for n in sel:
                    ChamferStuff(n.id+counter,n.radius)
            	counter +=1
            def ChamferStuff(id,Radius) :
                #doesomething
