    Snap mouse pointer to object?
    7 Posts 0 Posters 573 Views
      On 31/03/2012 at 09:44, xxxxxxxx wrote:
      Cinema 4D Version:   12
      I've long wished for bezier spline tools in C4D. So that we can paint smooth accurate custom curves.
      The only way I see to draw a custom curved paint stroke in C4D is to use the spline shader. Which relies on UV's. Making it not very predictable or interactive.
      Is there a way to make the mouse pointer snap to a spline in the API?
      Or maybe a way to turn an object into a paintbrush somehow?
      If an object could be used to paint another object. Then I could snap that object to a spline path and create smooth custom paint strokes that way.
        On 31/03/2012 at 10:19, xxxxxxxx wrote:
        http://www.blackstar-solutions.de/index.php?id=11917
          On 31/03/2012 at 11:12, xxxxxxxx wrote:
          That's cool.
          But it doesn't help me learn how to make it myself.
            On 02/04/2012 at 10:29, xxxxxxxx wrote:
            You may check the Snapping library and its main class, DetectSnapping.
            If you want to use it in a tool plugin, here is how to initialize and invoke this class in ToolData::MouseInput() :
            Bool MyToolData::MouseInput(BaseDocument* doc, BaseContainer& data, BaseDraw* bd, EditorWindow* win, const BaseContainer& msg)
                AutoAlloc<DetectSnapping> snap;
                if (!snap) return FALSE;
                snap->Init(doc, bd, NULL, Vector(), 0, FALSE, TRUE, TRUE);
                Vector delta;
                Vector pos = bd->SW(Vector(Real(msg.GetLong(BFM_INPUT_X)), Real(msg.GetLong(BFM_INPUT_Y)), RCO 0));
                if (snap->SnapTo(pos, &delta))
                    pos += delta;
              On 02/04/2012 at 11:53, xxxxxxxx wrote:
              Thanks Yannick.
              Sorry for being stupid.
              But when I use that code in a tool plugin. Nothing happens.
                On 02/04/2012 at 14:13, xxxxxxxx wrote:
                Yannick code is fine you only have to apply it in your case.
                here a little example try to put it in liquid tool in c4dsdk example and remember to turn on and set snap settings:
                Bool LiquidToolData::MouseInput(BaseDocument *doc, BaseContainer &data;, BaseDraw *bd,EditorWindow *win, const BaseContainer &msg;)
                     //get mouse position
                     Real                    mx = msg.GetReal(BFM_INPUT_X);
                     Real                    my = msg.GetReal(BFM_INPUT_Y);
                     Vector               pos = bd->SW(Vector(mx, my, 500)); // bring mouse pos in world space
                     Vector               delta = Vector();
                     BaseObject     *active = doc->GetActiveObject(); // get the active object
                     LONG                    button;
                     switch (msg.GetLong(BFM_INPUT_CHANNEL))
                          case BFM_INPUT_MOUSELEFT : button=KEY_MLEFT; break;
                          case BFM_INPUT_MOUSERIGHT: button=KEY_MRIGHT; break;
                          default: return TRUE;
                     if (!active) // if no active object create a new sphere and inser it in document
                          active = BaseObject::Alloc(Osphere);
                          if (!active) return FALSE;
                          doc->InsertObject(active, NULL, NULL, TRUE);
                          active->SetAbsPos(pos);
                     AutoAlloc<DetectSnapping>snap; // alloc the snap
                     snap->Init(doc, bd, NULL, Vector(), 0, FALSE, TRUE, TRUE); // initialize snap
                     Real                         dx,dy;
                     BaseContainer bc;
                     BaseContainer device;
                     win->MouseDragStart(button,mx,my,MOUSEDRAGFLAGS_DONTHIDEMOUSE|MOUSEDRAGFLAGS_NOMOVE);
                     while (win->MouseDrag(&dx;,&dy;,&device;)==MOUSEDRAGRESULT_CONTINUE) // start drag
                          // increment mouse position during drag
                          mx+=dx;
                          my+=dy;
                          pos = bd->SW(Vector(mx, my, 500)); // update pos
                          if (snap->SnapTo(pos, δ)) // if point snap anywhere
                               pos += delta; // pos will be updated with snapped delta
                          if (active) active->SetAbsPos(pos); // set the object position to the new one!
                          DrawViews(DRAWFLAGS_ONLY_ACTIVE_VIEW|DRAWFLAGS_NO_THREAD|DRAWFLAGS_NO_ANIMATION); //update viewport
                     win->MouseDragEnd(); // reset viewport status
                     EventAdd();
                i hope this help
                Franz
                  On 02/04/2012 at 15:24, xxxxxxxx wrote:
                  Thank you Franz. That does make it more clear.🍺
                  That gives me a way to snap an object to a spline. While also staying attached to the mouse cursor.
                  Acting like a brush.
                  But now I have to somehow paint with that object. Like that paint shader does.
                  Any ideas how I would accomplish that?
