    Axis position
    11 Posts 0 Posters 2.2k Views
      On 24/03/2012 at 07:16, xxxxxxxx wrote:
      Hi all Tongue
      very simple question, how to change the axis position (using python of course)?
      i can't find the Axis Modification command or something similar in the documentation, maybe i need to use matrix for that 🤢 ??
      an example 'll be very helpful.
      thanks in advance!
        On 24/03/2012 at 10:33, xxxxxxxx wrote:
        axis are just a representation of the difference of local and global coordinates. and yes you will have
        to use matrices 🙂
        edit :
        here is the main entry point to mess with local/global coordinates.
        http://www.thirdpartyplugins.com/python/modules/c4d/C4DAtom/GeListNode/BaseList2D/BaseObject/index.html#c4d.BaseObject
          On 24/03/2012 at 11:18, xxxxxxxx wrote:
          thank you littledevil for your answer 🙂
          i know that axis are just a representation. to get this, i use usually
          obj.GetMg().off
          the problem is, if i change these coordinates, the object will move too, and i need to keep the object in the same postion.
            On 24/03/2012 at 14:00, xxxxxxxx wrote:
            You can only move the axis for point object.
            You first store the original points, move the object, then reset the points
            to the original positions.
            This command example moves the axis to the parent.
            Lennart
            # MoveAxisOnly tcastudios©2012
            # Move the axis of a point object and keep points at original local(parent) position
            from c4d import Vector as v
                if op is None or not op.CheckType(c4d.Opoint) : return False
                oldm   = op.GetMg()
                points = op.GetAllPoints()
                pcount = op.GetPointCount()
                doc.StartUndo()
                op.SetAbsRot(v(0))
                op.SetAbsPos(v(0))
                op.Message(c4d.MSG_UPDATE)
                newm    = op.GetMg()
                for p in xrange(pcount) :
                    op.SetPoint(p,~newm*oldm*points[p])
                doc.EndUndo()
              On 25/03/2012 at 06:52, xxxxxxxx wrote:
              i got the idea, thank you very much Lennart 🙂
                On 27/03/2012 at 07:25, xxxxxxxx wrote:
                This one demonstrates a little other approach and is about 2 lines shorter than Lennarts version. Tongue
                # coding:      ascii
                # file:        <scriptmanager>
                # description: Reset an object's position to the origin while its points keep
                #              their position globally.
                  if not op or not op.CheckType(c4d.Opoint) :
                  mg     = op.GetMg()
                  # tell c4d to encapsulate the following steps into a single
                  # undo step
                  doc.StartUndo()
                  for i in xrange(pcount) :
                      point = op.GetPoint(i)
                      op.SetPoint(i, point * mg)
                  op.SetAbsPos(c4d.Vector(0))
                  op.SetAbsRot(c4d.Vector(0))
                  # close the undo encapsulation and tell c4d to update the gui
                  doc.EndUndo()
                Cheers!
                -Niklas
                  On 27/03/2012 at 09:10, xxxxxxxx wrote:
                  Hi Niklas, put a timer in them and explore:)
                  Lennart
                    On 24/10/2012 at 08:01, xxxxxxxx wrote:
                    Hello ,
                    I tried to change your script to set the axis to the center of the bounding box with
                    #newm    = op.GetMg()
                    newm    = op.GetMp()
                    but i get a float instead of vector error?
                    File "'scriptmanager'", line 32, in <module>
                    File "'scriptmanager'", line 25, in main
                    TypeError: argument 2 must be c4d.Vector, not float
                    any ideas ?
                    kind regards mogh
                      On 24/10/2012 at 11:21, xxxxxxxx wrote:
                      Possibly because GetMg() does not return a matrix, but a *Vector*.
                      Didn't check it, however.
                        On 25/10/2012 at 00:21, xxxxxxxx wrote:
                        but
                        opt.SetMg(newm)
                        says it wants a vector ?
                        anyway how do i get a matrix from a single vector remaining the orientation.
                        I am sorry, math is not my profession ...
                        kind regards
                          On 29/10/2012 at 01:52, xxxxxxxx wrote:
                          Code Vonc
                          has some interesting stuff - still getting nowhere
                          http://code.vonc.fr/?a=22
                          kind regards
