    Py4d beginner
    3 Posts 0 Posters 413 Views
      On 19/03/2012 at 12:37, xxxxxxxx wrote:
      I started learning Python about 1 year ago, I'm fimiliar with Pythonsyntax and meanwhile with OOP structures as well.
      Now I'm trying to get deeper into Py4d so these are my first steps.
      I have a very basic problem:
      from c4d import gui
      gui.QuestionDialog("Do you think I am a dialog?")
      if True:
        print ("You are right.\n I am a dialog")
        print ("You are wrong.\n I really am a dialog.")
      Basicly this works but its buggy.
      The documentation says the gui.QuestionDialog() pops up a dialog with a "yes" and "no" button and returns ****True if the user answered Yes, otherwise False.
      But in my case I get True either way, at least I get the print from the True value either way. No matter if click "yes" or "no".
      Why? ****
        On 19/03/2012 at 12:49, xxxxxxxx wrote:
        Hi kornyclown,
        You need to assign the return-value of the function to a variable and test that variable in the
        if-clause. Checking for if True: will always succeed because True actually is True.
        from c4d import gui
        answer = gui.QuestionDialog("Do you think I am a dialog?")
        if answer:
        -Niklas
          On 19/03/2012 at 13:31, xxxxxxxx wrote:
          Ah, ok that makes sense, I didn't consider that True is always True. I was thingking a bit too "human".
          Works fine, thanks a lot.
