    C4D file format
    Scheduled Pinned Locked Moved General Discussion
    13 Posts 0 Posters 1.9k Views
      On 19/03/2012 at 11:52, xxxxxxxx wrote:
      I don't think so as XML is an open file-format (and human readable). Doesn't ActionScript come with an XML parser?
      -Niklas
        On 19/03/2012 at 12:06, xxxxxxxx wrote:
        Yes, it comes. It sounds reasonable to me, thanks.
          On 20/03/2012 at 01:17, xxxxxxxx wrote:
          Just be aware that the Cinema XML format can change at any point. It's rather meant for debbuging purposes etc.
            On 28/03/2012 at 08:18, xxxxxxxx wrote:
            Why not use one of the standard exchange formats available in Cinema 4D such as FBX and COLLADA.  These include very detailed information such as mesh, uvs, materials, skeleton rigging, pose/animation and so on.  Then all you need is a parser for one of these exchange format to do the trick.
              On 13/04/2012 at 05:18, xxxxxxxx wrote:
              That is what I started to do finally. I've finished the parser, but I can't export any animation from Cinema 4D to COLLADA. What types of animations Cinema 4D can export to this format?
                On 13/04/2012 at 05:55, xxxxxxxx wrote:
                When I look into the exported COLLADA file everything is ok except that there is no<animation> tags. Cinema doesn't export even simple keyframe animations with recorded positions.
                Cinema version which I have possibility to use is R12.
                  On 13/04/2012 at 15:34, xxxxxxxx wrote:
                  I have found an example COLLADA file with joint animations. It is imported and exported correctly. However, after import, Cinema makes weird animated property tracks named "Transformed Rotation" and "Transformed Position". They are then exported correctly, while regular "Position" and "Rotation" tracks are not exported - they are completely ignored.
                    On 14/04/2012 at 00:13, xxxxxxxx wrote:
                    I've tried the same thing in Cinema 4D R13 demo and everything is ok now. That R12 was not updated as it's owner has slow wireless connection. Possibly that was a problem.
                      On 04/06/2012 at 01:56, xxxxxxxx wrote:
                      You tell that .c4d is  a proprietary format, but then what is the following documentation ?
                      [URL-REMOVED]
                      It seems to be a description of the .c4d V5 file format ?
                      Unfortunately I have't found any C++ example to read the file !
                      Does someone has more information ?
                        On 04/06/2012 at 06:08, xxxxxxxx wrote:
                        There are no examples for the V5 file format because it's not recommended to use and we can't provide any support for it. Sorry.
                        It's possible to read and write Cinema files through our Melange library though.
