    Understanding the Cache
    3 Posts 0 Posters 436 Views
      On 13/03/2012 at 05:35, xxxxxxxx wrote:
      I still don't understand how caching in Cinema 4D works. I can obtain the virtual object hierarchy using c4d.BaseObject.GetCache(). The returned hierarchy is exactly the same as the object keeps a reference to. That means, modifieng the hierarchy returned by ~.GetCache() takes immidiate effect on the generator object, as I'm modifieng it directly.
      For example, when I create a standart Cloner object and execute this script in the Script Manager
        cache = op.GetCache()
        for child in cache.GetChildren() :
            pos = child.GetAbsPos()
            child.SetAbsPos(pos * 2)
      This will immidiately double the clones positions. However, this will only last until the Cloner's cache is being rebuilt again.
      So far, so good. Let's say I'd like to modify the points of a primitive cube continiously. I'd create a PythonTag, get the cache in it and modify that cache. As the PythonTag is executed even has not been rebuilt, I need to check if the cache has changed the last time I modified it.
      prevDirty = 0
        global prevDirty
        og = op.GetOrigin()
        dirty = og.GetDirty(c4d.DIRTY_CACHE)
        if prevDirty < dirty:
            cache = og.GetCache()
            for i, p in enumerate(cache.GetAllPoints()) :
                cache.SetPoint(i, p * 2)
            cache.Message(c4d.MSG_UPDATE)
        prevDirty = dirty
      This works pretty fine. But when you hit Render To Picture Viewer, you can see that the cube has still it's original size in the first frame but was affected correctly in all other frames. (Don't forget to set the Tags priority to Generators, Thanks to Lennart [tcastudios]).
      I also noticed that this seems to work most time in the Physical renderer, but not in the Advanced, Software or Hardware renderer.
      How can I modify the cache so it does have effect to the rendered object?**
      Thanks very much,
      Niklas
      PS: Here is another example scene with a tag modifieng a cloner's cache.
        On 13/03/2012 at 05:59, xxxxxxxx wrote:
        As far as I understand, cache and deformcache are read only.
        The SDK states that caches are not to be modified and that is maybe
        why things are funky in your tests?
        Lennart
          On 15/03/2012 at 14:21, xxxxxxxx wrote:
          That might be the reason Lennart. But I am curious how, for example, the Dynamics Tag is implemented if they are not allowed to modify the cache? Or the ChamferMaker plugin?
          Thank you!
          -Niklas
