    too stupid for description system :)
    14 Posts 0 Posters 1.4k Views
      On 12/03/2012 at 20:08, xxxxxxxx wrote:
      thank for your reply, the console still returns:
      > AttributeError: 'module' object has no attribute 'SEENBYBYCAMERA'
      for :
      	def Init(self, op) :
      		data = op.GetDataInstance()
      		data.SetVector(c4d.LIGHT_COLOR,c4d.Vector(1.0,1.0,1.0))
      		data.SetReal(c4d.LIGHT_BRIGHTNESS,1.0)
      		data.SetLong(c4d.LIGHT_TYPE,1)
      		data.SetLong(c4d.EMITDIRECTION,2)
      		data.SetLong(c4d.SAMPLINGMODE,2)
      		data.SetLong(c4d.MAXIMUMSAMPLES,128)
      		data.SetReal(c4d.ACCURACY,0.65)
      		data.SetBool(c4d.ACCURATECOLOR, True)
      		data.SetBool(c4d.ISAREALIGHT, True)
      		data.SetBool(c4d.SEENBYGI, True)
      		data.SetBool(c4d.SEENBYBYCAMERA, True)
      		data.SetBool(c4d.SEENBYBYREFLECTIONS, True)
      		data.SetBool(c4d.SEENBYBYREFRACTIONS, True)
      		data.SetLong(c4d.DISPLAYMODE,2)
      gnahgnahgnah ...
      edit : it is in this semi-working state like it is when i remove :
      	op[c4d.SEENBYBYREFLECTIONS] = True
      	op[c4d.SEENBYBYREFRACTIONS] = True
      1-4 correct, 5-7 wrong, 8-9 correct, 10-11 wrong, 12 correct, 13-14 wrong ... oO
        On 12/03/2012 at 20:27, xxxxxxxx wrote:
        "SEENBYBYCAMERA" ? ๐Ÿ™‚
        Lennart
          On 12/03/2012 at 20:33, xxxxxxxx wrote:
          Lennart
          not sure what you want to say ? SEENBYCAMERA like the boolean in the compositing tag.
            On 12/03/2012 at 20:39, xxxxxxxx wrote:
            seenBYBYcamera, I guess it easy to get "word blind".
            Check the spelling:)
            Lennart
              On 12/03/2012 at 20:49, xxxxxxxx wrote:
              weeh,
              its far too late for me ๐Ÿ™‚ however, after correcting the typo the console returns :
              _ AttributeError: 'module' object has no attribute 'SEENBYREFLECTIONS'ย _
              _
              _
              the funny thing is, c4d.SEENBYREFLECTIONS is true and its checkbox is checked. if there is a god, its a cruel one ๐Ÿ˜ž
                On 12/03/2012 at 21:52, xxxxxxxx wrote:
                Perhaps you are having trouble because you changed your descriptions. But didn't delete your coffeesymbolcache file?
                That one tends to burn everyone at least once.
                  On 13/03/2012 at 05:19, xxxxxxxx wrote:
                  To me,
                  ย ย ย ย self.InitAttr(op, bool, [c4d.SEENBYBYREFLECTIONS])
                  ย ย ย ย self.InitAttr(op, bool, [c4d.SEENBYBYREFRACTIONS])
                  looks spelt wrong "..BYBY.." but also as Scott mentioned,
                  the coffesymbolcache file might need to be deleted for
                  Cinema to update it.
                  Lennart
                    On 13/03/2012 at 09:22, xxxxxxxx wrote:
                    that did the trick ๐Ÿ™‚ cannot express it in words how gratefull i am for your help and how angry i am, that neither the c++ sdk nor the python sdk mention this with a word (at least at their description sections).
                      On 13/03/2012 at 09:37, xxxxxxxx wrote:
                      The file is located here on a Windows OS:C:\YOUR username here\user\AppData\Roaming\MAXON\YOUR c4d version here\prefs\coffeesymbolcache
                      You didn't specify Mac or PC. Or what version you're using.
                      There are a great many differences between R12 & R13. So please always provide that info in your posts.
                      BTW: I don't know if you know this or not. But the file link you posted says I need special permission from you to download it. That's not going to get you a lot of help either. ๐Ÿ˜‰
                        On 13/03/2012 at 09:54, xxxxxxxx wrote:
                        sorry about the google docs. but the problem is solved i found the file and it works, again thanks for your help ๐Ÿ™‚
                          On 13/03/2012 at 10:14, xxxxxxxx wrote:
                          Lol.
                          That stupid cache file thing is sort of a rite of passage that all python plugin newbies have to go through.
                          It's sort of like a fraternity hazing...Everyone has to go through it at least once to be in the club.๐Ÿ˜‚
