    Tp Born Position
    5 Posts 0 Posters 566 Views
      On 03/03/2012 at 17:28, xxxxxxxx wrote:
      Hi all,
      I'm trying to storage the position of all particles of a group when were born.
      Here's my code:
          tp = doc.GetParticleSystem()
          TpGroupA = op[c4d.ID_USERDATA,1]
          cntGroupA = TpGroupA.NumParticles()
          PPGroupA = TpGroupA.GetParticles()
          PPGroupStart = c4d.Vector
          PPGroupStartPos = []
          for i in xrange (cntGroupA) :
              if tp.IsBorn(i)==True:
                  PPGroupStart = tp.Position(PPGroupA _)
                  tp.SetPData(i,0,PPGroupStart) # I  have created a Channels (vector) where storage the position
              PPGroupStartPos.append(tp.GetPData(i,0))
      But it works only when I play the scene from the first frame... If I jump from a frame to another the Channel value became "None"
      What's wrong in this code?
      There's another way retrive the born position of particle?
      Luther
        On 06/03/2012 at 17:35, xxxxxxxx wrote:
        not sure hat is going wrong, but the setup looks quite compilacted. why don't you use just a python node with a TpParticle input port and plug a PPass node into it ? the *code *would be :
        mycache = []
            if tp.IsBorn(pid) :
                tp.SetPData(pid, 0, tp.Position(pid))
                mycache.append(tp.Position(pid))
        can't see a reason to do the iteration stuff yourself 🙂 (ps : tp as the documents master particle system is predefined and pid is the name of my TpParticle input port)
          On 09/03/2012 at 05:44, xxxxxxxx wrote:
          Hi Little Devil,
          thank you so much for you reply. I'm a little bit confused, I think that I don't understand very well what do you suggest.
          I attach my c4d scene, so you can see what I really want to do:
          https://docs.google.com/open?id=0B4E_u8h_R81SSGdrX1BnZkdTRm1Nb0VLblM5VVZuUQ
          Another thing, in a older your post I read that if I want to generate all particles at frame 0 I have to cache first my particle. Can you write me a little example of this code?
          Luther
            On 09/03/2012 at 13:37, xxxxxxxx wrote:
            i think i am getting something wrong, it is very simple, i have attached an example.
            http://www.2shared.com/file/mpgLW-\_R/LineStartPGroup002.html
            to your second question : can't see a reason for this, please explain what you want to achieve. basicly it would be the same. check if it is frame 0, check if particle id is related to a born particle and then do something with this id.
              On 13/03/2012 at 06:02, xxxxxxxx wrote:
              Hi Little Devil,
              sorry for the late responce... Thank you so much for you reply, now I have understand.
              For the second question, never mind... I was confused 🙂
