    Polling within a textbox
    15 Posts 0 Posters 1.5k Views
      On 28/02/2012 at 12:01, xxxxxxxx wrote:
      @Yannick,
      I can't use command because that would require the user to physically click on a button, or some other gizmo, to poll the textbox.
      I'm trying to make this happen live. So when the user types "." in the textbox. A ComboButton or a popup list will pop up. And the user can select one of the options. Which will add it to the right of the "." in the text box.
      @Steve,
      What is making this so much harder is that I'm using a dialog plugin.
      There's lots of examples for tags and objects plugins. But they are a little bit easier because *Node  and * Type are built into them. And you can just use them.
      And although dialogs do have the GetDDescription() where these things are available. I don't know how to execute them from one of the other methods at a specific time.
      In other words. I don't understand how GetDDescription() communicates with Message(), Command(), Init(), ect...
      A tutorial about this stuff would be wonderful.
      Thanks for the help,
        On 28/02/2012 at 15:14, xxxxxxxx wrote:
        What's confusing you is probably what confused me at first - you have functions with the same name doing the same overall thing but in a different way. For instance, Atom::Message is quite different from the Message() in the classes derived from BaseData, which is the base class for tool, tags, etc. Then there's GeDialog::Message, which is not derived from Atom but which appears to receive exactly the same messages.
        On top of that you have GeDialog::Command, which indicates that the user has changed something or clicked a button, a function which in descriptions is handled through Message() (there is no Command() for descriptions).
        I can't help thinking that this is the result of years of code being added on and all piled on top without much attempt to rationalise it - probably because, in fairness, to do that would break so much existing code.
        But I'll see what I can do about a descriptions tutorial.
        Steve
          On 28/02/2012 at 16:27, xxxxxxxx wrote:
          Ok. Thanks.
          I can't speak for anyone else. But a tutorial on it would really help me a lot.
          Dialog descriptions. What they can, and can't do(example: hide or alter GUI items) are especially confusing to me. But I'm also not really that clear on the tag and object type descriptions too.
          On top of that. I might be trying to do something that just isn't possible in C4D with this live polling of what's being typed into a textbox thing.
          I've seen people do it in raw C#. But I don't know if it's possible in C4D.
            On 28/02/2012 at 22:20, xxxxxxxx wrote:
            Here is how I've been able to poll the string in an EditText (using Command(), still don't understand why you don't want to use it) and display a PopupMenu:
            class PollTextDialog : public GeDialog
                virtual Bool CreateLayout(void)
                    // first call the parent instance
            	    Bool res = GeDialog::CreateLayout();
            	    SetTitle("Poll Text Dialog");
                    GroupBegin(0, BFH_SCALEFIT, 0, 1, String(), 0);
                    AddEditText(1028, BFH_SCALEFIT, 150);
                    GroupEnd();
                    return res;
                virtual Bool Command(LONG id, const BaseContainer &msg)
                    if (id==1028)
                        String str;
                        if (GetString(1028, str))
                            BaseContainer msg(BFM_EDITFIELD_GETCURSORPOS);
                            GeData data = SendMessage(1028, msg);
                            LONG pos = data.GetLong();
                            if (pos > 0 && str[pos-1]=='.')
                                LONG editX, editY, editW, editH;
                                if (GetItemDim(1028, &editX, &editY, &editW, &editH))
                                    if (Local2Screen(&editX, &editY))
                                        BaseContainer entries;
                                        entries.SetString(FIRST_POPUP_ID+0, "Item1");
                                        entries.SetString(FIRST_POPUP_ID+1, "Item2");
                                        entries.SetString(FIRST_POPUP_ID+2, "Item3");
                                        LONG res = ShowPopupMenu(NULL, editX+(pos*5), editY+editH, entries);
                                        if (res!=NULL)
                                            str += entries.GetString(res);
                                            SetString(1028, str);
                                            BaseContainer msg(BFM_EDITFIELD_SETCURSORPOS);
                                            msg.SetLong(1, str.GetLength());
                    return GeDialog::Command(id,msg);
            I'm still trying to get the pixel position of the cursor in the EditText to open the PopupMenu just below it.
            Edit : changed editX to editX+(pos*5)
              On 28/02/2012 at 23:23, xxxxxxxx wrote:
              You've got some R13 only stuff in there and I'm not set up to compile for R13 at the moment.
              When I was getting undefined errors I took a look at the R13 Docs. And noticed that there's a ton of new stuff they added that might easily go unnoticed. Including cursor   position(BFM_EDITFIELD_GETCURSORPOS) that isn't in R12.
              I'll have to try and get myself set up with the R13 demo so I can try out your code.
              Looks like they added some neat things that I wasn't even aware of in R13.
              Thanks a ton for the example.🍺
              *Edit-- I just got things set up for R13 and it works like a charm. Very cool stuff.
                Ah sorry, didn't remembered you're working with R12.
                Glad you could try the code. The 'magic' size of a character's is not good practice but SizeChr() doesn't give a useful value in this case. I'm not sure if this hardcoded size works for both Windows and Mac.
                  On 29/02/2012 at 15:50, xxxxxxxx wrote:
                  Yannick.
                  Do you know if this same thing is possible to do in R12?
                  I've been trying the various BFM's that are in R12. But I can't make the popup GUI trigger while the cursor is still inside of the textbox.
                  It will trigger the popup once I click someplace else in the dialog. But this is of course not a desired result.
                  I think I'm using the BFM's wrong:
                     if(id==MY_TEXT_FIELD)
                       String text;                                      //Create a variable to assign to the text that's in the textbox
                       if(GetString(MY_TEXT_FIELD, text))                //Get the text using that new variable
                         msg.GetLong(BFM_INPUT_DEVICE) == BFM_INPUT_KEYBOARD;//<---Wrong?
                         LONG slength = text.GetLength();                    //Get the total size of the string
                         LONG editX, editY, editW, editH;                            //Create some variables to position the popup GUI
                         GetItemDim(MY_TEXT_FIELD, &editX, &editY, &editW, &editH);
                         Local2Screen(&editX, &editY);
                         if(slength > 10)  //<--This value is the trigger for the popup to execute
                          LONG popup = ShowPopupMenu(NULL, editX, editY+editH, entries);
                          if(popup!=NULL)
                            text += entries.GetString(popup);
                            SetString(MY_TEXT_FIELD, text);
                            GeData data = SendMessage(MY_TEXT_FIELD, msg);  //<---either Wrong or not working
                    On 08/03/2012 at 00:34, xxxxxxxx wrote:
                    Hi Scott,
                    I'm not quite sure, if I understood your "live polling" question correctly and if your actual request has been solved.
                    As you seem to be in a dialog, I think you could have another look at my ColourTable example (I posted a link in "Descriptions Vs. AddItem" thread). There I'm coloring the cursor, while the user is typing, depending on a search result (see ColourTableSubDialog::ColorSearchAndSet(void), which is called from Command()).
                    And then you were asking, how to stop working on the text field input, as Message() or Command() are called over and over. Couldn't you just store the text input and do your thing, only if the actual data changed. This also opens the possibility to filter strange user inputs or to do nothing, if the user changed the field but ended up with the same input...
                    Hope this was of any help,
                    Andreas
                      On 08/03/2012 at 08:37, xxxxxxxx wrote:
                      Hi Andreas,
                      I'll take another look at your files. And see if there's something in there that might help.
                        On 08/03/2012 at 11:35, xxxxxxxx wrote:
                        Scott, sorry, I forgot to mention the file: colourtable.cpp
