    Changing The Cursor: Using Dialogs
    3 Posts 0 Posters 332 Views
      On 26/02/2012 at 11:50, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hey guys,
      I'm having a hard time finding how to change the cursor's appearance within C++ dialog plugins.
      I can get the LMB state and store the desired cursor appearance type into a BaseContainer just fine.
      And when I use the LMB it does print the correct ID# for that cursor type. But I can't make the cursor's appearance change.
      LONG myDialog::Message(const BaseContainer &msg, BaseContainer &result)
        BaseContainer bc;                                                  //Used to hold the type of cursor to display
        BaseContainer state;                                               //Used to hold the state of the LMB
        while (GetInputState(BFM_INPUT_MOUSE, BFM_INPUT_MOUSELEFT, state)) //While the LMB is held down
         if(state.GetLong(BFM_INPUT_VALUE) == 0) break; //If the state value is 0. The LMB is no longer down..so exit the loop
         LONG x = state.GetLong(BFM_INPUT_X); //Get the cursor's X screen coordinates
         LONG y = state.GetLong(BFM_INPUT_Y); //Get the cursor's Y screen coordinates
         //GePrint(LongToString(x));
         //GePrint(LongToString(y));
         bc.SetLong(RESULT_CURSOR,MOUSE_POINT_HAND);          //Store the cursor type into the container
         GePrint(LongToString(bc.GetLong(RESULT_CURSOR)));    //Prints #19 when the LMB is pressed...Working good so far...
         if (bc.GetId()==MOUSE_POINT_HAND) return TRUE;    //<---Wrong?
        // ...do more stuff
        return GeDialog::Message(msg,result);
      When using the GetCursorInfo() method. They just use SetLong(). And for some reason it works.
      But since I'm using a dialog plugin. I can't use GetCursorInfo(). And using SetLong() isn't working for me.
      What am I missing?
        On 26/02/2012 at 16:57, xxxxxxxx wrote:
        Use GeShowMouse() to set the cursor type (from anywhere).
          On 26/02/2012 at 17:29, xxxxxxxx wrote:
          Thanks Robert. 🍺
