    Scripts that need to be executed twice?
    3 Posts 0 Posters 452 Views
      On 20/02/2012 at 09:37, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :   C.O.F.F.E.E  ;  C++  ;   PYTHON  ;
      Every once in a while I run across a strange scripting behavior where a piece of the code gets skipped over. And requires me to execute the script a second time.
      It typically most often happens when moving objects in the hierarchy. Then trying to do something on that object.
      It's almost as if C4D has a hard coded time limit to execute lines of code. And if anything takes more than a couple of cycles(like editing the OM). C4D can sometimes skip over the lines of code following that task!
      I can usually hack around these kinds of problems.
      But here's an example where the problem is really, really bad:
        for i in range(2) : #Cheats the script to work...this script dos not work in one click!!
        op = doc.GetActiveObject()
        points = op.GetAllPoints()
        mtx = op.GetMg()
        inv = mtx.__invert__()
        gpoints = []              #Used to hold the points original global positions
        for i, point in enumerate(points) :
            lpoints = points _    #The local position of each point
            gpnt = inv*point      #The global position of each point
            gpoints.append(gpnt)  #Add each global point position to the list
        doc.StartUndo()
        doc.EndUndo()
        op.SetAbsPos(c4d.Vector(150,300,300)) #Move the object's axis
        op.Message(c4d.MSG_UPDATE)            #Tell C4d the object moved
        op.SetAllPoints(gpoints)   #Move the points back to their original positions
      This example is in python. But it also happens in Coffee(and I assume C++) too.
      All I want to do is make my script do this:
      - Save an object's global point positions in an array
      - Move the object someplace else in the scene
      - Restore the points back to their original positions
      It's acting like the object is still at 0,0,0 and never gets updated that the object has been moved.
      And it's also doing that annoying thing where I have to execute it twice. Because once it reaches SetAbsPos(). It completely ignores the SetAllPoints() code that comes after it!
      Why does this happen?
      Is there a work around, or different approach I should use for this kind of situation that the script manager can handle better?
      _
        On 20/02/2012 at 11:08, xxxxxxxx wrote:
        To me it looks as if you miss the new matrix after movement
        to use as new base and your script reads the new base on the second
        pass. (And the doc.EndUndo should be last after all your changes)
        Lennart
            if op is None: return False
            oldm   = op.GetMg()
            pcount = op.GetPointCount()
            doc.StartUndo()
            newm    = op.GetMg()
            for p in xrange(pcount) :
                op.SetPoint(p,~newm*oldm*points[p])
            doc.EndUndo()
          On 20/02/2012 at 12:24, xxxxxxxx wrote:
          Thanks Lennart.🍺
          I didn't realize that I needed to grab the matrix twice like that. But I think I can see why it's necessary.
