    GeDialog & SystemError: error return without excep
    5 Posts 0 Posters 599 Views
      On 20/02/2012 at 09:14, xxxxxxxx wrote:
      Exception in thread Thread-1:
        File "/Applications/MAXON/CINEMA 4D R12 Dev/resource/modules/python/res/Python.osx.framework/lib/python2.6/threading.py", line 525, in __bootstrap_inner
        self.run()
        File "/Applications/MAXON/CINEMA 4D R12 Dev/plugins/plugin-test/package/repeattimer.py", line 74, in run
        self.update(self.counter)
        File "/Applications/MAXON/CINEMA 4D R12 Dev/plugins/plugin-test/package/mycommanddata.py", line 35, in timerCall
        self.__dialog.updateJobDetails(self.__jobChecker.jobDetails)
        File "/Applications/MAXON/CINEMA 4D R12 Dev/plugins/plugin-test/package/mydialog.py", line 42, in updateJobDetails
        self.AddStaticText(2000, c4d.BFH_CENTER, 200, 20, "buttonName")
      SystemError: error return without exception set
      I keep getting "SystemError: error return without exception set" when I try to update the GeDialog
      def updateJobDetails(self, jobDetails) :
           self.jobDetails = jobDetails
           self.LayoutFlushGroup(2)
            numJobs = int(len(self.jobDetails))
            print "numJobs ", numJobs
            self.GroupBegin(id=4, flags=c4d.BFH_LEFT | c4d.BFV_TOP, title="", rows=1, cols=1, groupflags=c4d.BORDER_GROUP_IN)
            buttonIDCount = 3000
            buttonIDList = []
            self.AddButton(2000, c4d.BFH_CENTER, 200, 20, "buttonName")
            self.GroupEnd()
            self.LayoutChanged(2)
      Is it not something I can do after the dialog window is built?
        On 20/02/2012 at 10:36, xxxxxxxx wrote:
        Yes, you usually can.
        Are you using threads? Would be useful to see the full code here.
          On 20/02/2012 at 11:57, xxxxxxxx wrote:
          Yes, i'm using a timer thread.
          Although I should probably re-work my code as the c4d gui class has a timer built in...all i'm using it for is checking a directory structure every 5 seconds.
          bit strange how a thread can effect the GeDialog, i can make Groups but can't make any C4Dgadgets (buttons/static text/radio buttons etc)
          will post the code when i'm back in work 🙂
          cheers
            On 20/02/2012 at 12:02, xxxxxxxx wrote:
            Good, I can will then take a look at it. Especially the part where the timer-thread notifies the dialog.
            You should always modify the dialog when it is called from Cinema 4D, which means in it's own thread, not one you started.
            Niklas
              On 21/02/2012 at 03:40, xxxxxxxx wrote:
              Yeah it was because I had my own thread initiated.
              using C4D's GeDialog->Timer does the trick!
              thanks for your help!
