    Long Script Loops_Threading?
    7 Posts 0 Posters 577 Views
      On 11/02/2012 at 14:30, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Language(s) :     C++  ;   PYTHON  ;
      I have a script that creates splines from the selected polygon object.
      I basically just wrote my own version of the ExplodeSegments command. But it creates splines instead of polygon objects.
      The problem is. Depending on how many splines I'm creating. It can take several minutes for this script to finish running. And for some reason the spinning bar that I've written into the code stops animating after 10-15 seconds. And C4D acts like it's locked up and not responding.
      But if I let the script finish...Eventually it finished and everything goes as it should.
      Obviously this is bad. And I need to make C4D handle this better.
      I've tried using StopAllThreads() in various places. And it doesn't seem to help.
      How can I make scripts like this run better. And not lock up the UI and the spinning progress bar?
        On 11/02/2012 at 17:42, xxxxxxxx wrote:
        You would need to spawn a separate thread and do your work from it since the default one is the main thread (which is why C4D locks up).
          On 11/02/2012 at 19:27, xxxxxxxx wrote:
          I've never worked with threads before. Totally green.
          Any tips that might help me at least get started on it?
          I'm not seeing much in the SDK or the docs about threading to learn how to do it.
          And I'm not finding anything at all about threading scripts or command data plugins.
            On 12/02/2012 at 03:26, xxxxxxxx wrote:
            Hi Scott, threading in Python is easy, but I haven't worked with it in C/C++ yet.
            import threading
            class MyThread(threading.Thread) :
              def run(self) :
                  "do what you want to do in the thread, here."
            thread = MyThread()
            thread.start()
            # process stuff while the thread is doing his work
            thread.join() # waits until the thread finished it's work
            An alternative would be
            def myThreadedFunction() :
            thread = threading.Thread(target=myThreadedFunction)
            You can also overwrite the constructor an add your custom arguments.
            Here's more about threading: http://docs.python.org/library/threading.html
              On 12/02/2012 at 06:22, xxxxxxxx wrote:
              In C++, you need two parts, a controller class and a thread class derived from Thread.  Here are simplified header and source for each:
              // ControlThread.h
              #ifndef _CONTROLTHREAD_H_
              #define _CONTROLTHREAD_H_
              #include "c4d.h"
              #include "GMPThread.h"
              // CLASS: ControlThread
              class ControlThread : public Thread
                    // Data
                    // - MP Thread related
                    LONG                cpu_count;
              #ifdef    C4D_R12
                    MPThreadPool        mp;
              #else
                    MPThread            mp;
              #endif
                    GMPThread            thread[MAX_THREADS];
                    Thread*                tlist[MAX_THREADS];
                    // Methods
                    ControlThread();
                    ~ControlThread();
                    // - Thread
                    void                Main();
                    const CHAR*            GetThreadName() { return "ControlThread"; }
                    // - ControlThread
                    Bool                Initialize();
              #endif //_CONTROLTHREAD_H_
              // ControlThread.cpp
              #include "ControlThread.h"
              // METHODS: ControlThread ======================================================================================================
              // Constructor
              ControlThread::ControlThread()
              // Destructor
              ControlThread::~ControlThread()
              // Thread.Main
              // - This is the Multi-Processor Control Thread
              void ControlThread::Main()
              #ifdef    C4D_R11 // or later
                if (!mp.Start(THREADPRIORITY_NORMAL))    return;
              #else
                if (!mp.Start())    return;
              #endif
                mp.Wait();
              // ControlThread.Initialize
              Bool ControlThread::Initialize()
                // Get this once and for task-separation purposes
                cpu_count =                    GeGetCPUCount();
                for (LONG i = 0L; i != cpu_count; ++i)
                    tlist[i] =    &thread[i];
                    thread[i].Initialize(this);
                // Initialize MPThread for later use
                if (!mp.Init(*this,cpu_count,tlist))    return GePrint("ControlThread.Initialize.mp.Init()");
              // GMPThread.h
              #ifndef _GMPTHREAD_H_
              #define _GMPTHREAD_H_
              #include "c4d.h"
              #include "GMPSupport.h"
              // Predefines for GMPThread
              class ControlThread;
              // CLASS: GMPThread
              class GMPThread : public Thread
                private:
                    // Data
                    ControlThread*        cthread;
                    // Data
                    // Methods
                    GMPThread();
                    ~GMPThread();
                    // - Thread
                    void                Main();
                    const CHAR*            GetThreadName();
                    // - GMPThread
                    Bool                Initialize(ControlThread* ct);
              #endif //_GMPTHREAD_H_
              // GMPThread.cpp
              // METHODS: GMPThread ======================================================================================================
              // Constructor
              GMPThread::GMPThread()
              // Destructor
              GMPThread::~GMPThread()
              // Thread.GetThreadName
              const CHAR* GMPThread::GetThreadName()
                return "GMPThread";
              // GMPThread.Initialize
              Bool GMPThread::Initialize(ControlThread* ct)
                // Store ControlThread
                cthread =                ct;
              // Thread.Main
              // - This is the Single-Processor Thread
              void GMPThread::Main()
                // Do your thing! :)
              Initialize the threads through the controller class - only needs to be done once
              // - Main Multi-Processor Thread
                if (!cthread.Initialize())            return ErrorException::Throw(GeLoadString(GREERR_GENERAL), "GreeblerObj.Init.cthread");
              Start the thread or threads running:
              // - Begin Multiprocessing
                cthread.Start(THREADMODE_SYNCHRONOUS);
              A thread ends its active processing when it exits its Main() method.
                On 12/02/2012 at 08:22, xxxxxxxx wrote:
                Thanks a ton guys.🍺
                I'll take a look at your examples today and try to learn how it all works.
                  On 13/02/2012 at 01:33, xxxxxxxx wrote:
                  You can also take a look at the documentation of C4DThread class in c4d.threading module, there's a simple example showing how to use it.
