    Get BaseObject from Linkbox
    5 Posts 0 Posters 487 Views
      On 09/02/2012 at 06:56, xxxxxxxx wrote:
      Cinema 4D Version:   R13
      I'm trying to get BaseObject(s) from Linkbox of plugin.
      Using ResEdit plugin I've made a dialog which has two linkboxes so that I can drag two different objects into them to make a plugin that enables to swap their positions.
      For example,
      ID of each linkbox : IDC_OBJECT1, IDC_OBJECT2
      Members:
           BaseObject* op1, op2;
           LinkBoxGui* linkbox1;
           LinkBoxGui* linkbox2;
      I tried as following:
           linkbox1 = (LinkBoxGui* )FindCustomGui(IDC_OBJECT1, CUSTOMGUI_LINKBOX);
      However I don't know how to get the BaseObject from linkbox.
          op1 = ....?
      Or is there another way to do this?
      Thank you in advance. 🙂
        On 09/02/2012 at 08:15, xxxxxxxx wrote:
        You can call LinkBoxGui::GetLink() and cast the returned object to a BaseObject:
        BaseObject* op = (BaseObject* )linkbox->GetLink(GetActiveDocument(), Xlayer);
        This line is from the LayerShaderBrowser example.
        Regards,
          On 09/02/2012 at 18:04, xxxxxxxx wrote:
          Yannick Puech,  thank you for your answer.
          I tried as you guided, but I have still problems.
          In my opinion, the problems is caused by the second parameter of GetLink function, Xlayer,  corresponds only for shader instances.
          C++ HTML documentation reads:
          BaseList2D[URL-REMOVED]* GetLink(const BaseDocument[URL-REMOVED]* doc, LONG instance)_<_h4_>_
          However, I don't know what I have to put the second parameter, LONG instance, to get the BaseObject instance.
          My dialogbox, header files and cpp file look like this:
          Dialogbox: http://blog.naver.com/gchoi_acts/130130991792
          // c4d_symbols.h
          enum
            // Dialog definitions of IDD_SWAP_POSITION start here
            IDD_SWAP_POSITION, // ID of the Dialog Box
            IDC_OBJECT1, // ID of the first linkbox
            IDC_OBJECT2, // ID of the second linkbox
            // Dialog definitions of IDD_SWAP_POSITION end here
          // End of symbol definition
            _DUMMY_ELEMENT_
          // SwapPosition.h
          #include "c4d_gui.h"
          class SwapPosition : public GeDialog
          SwapPosition ();
          virtual ~SwapPosition ();
          virtual Bool InitValues(void);
          virtual Bool Command(LONG id, const BaseContainer &msg);
          virtual LONG Message(const BaseContainer& msg, BaseContainer& result);
          void UpdateAll(Bool msg);
          void \*lastselected;
          private:
          LONG lastdirty;
          BaseDocument* doc;
          LinkBoxGui* linkbox1, linkbox2;
          // SwapPosition.cpp
          #include "c4d.h"
          #include "c4d_symbols.h"
          #include "SwapPosition.h"
          Bool SwapPosition ::Command(LONG id, const BaseContainer &msg)
          //## GET USER ENTERED DATA:
          switch (id)
          case IDC_OK:
          if(!linkbox1) return FALSE;
          op1 = (BaseObject* )linkbox1->GetLink(GetActiveDocument(), Xlayer);
          	linkbox2 = (LinkBoxGui\* )FindCustomGui(IDC_OBJECT2, CUSTOMGUI_LINKBOX);
          	if(!linkbox2) return FALSE;
          	op2 = (BaseObject\* )linkbox2->GetLink(GetActiveDocument(), Xlayer);
          	GePrint("Object Name : " + op1->GetName());  // <======= ERROR OCCURRED
          	GePrint("Object Name : " + op2->GetName());  // <======= ERROR OCCURRED
          	break;
          case IDC_CANCEL:
          	break;
          default:
          	break;
          Thank you for your answer in adavance.
          Best regards,
          gchoi
            On 09/02/2012 at 18:48, xxxxxxxx wrote:
            Try Obase.
            If that works. There are other types listed under: OObjectType
            Just in case you need to use them some day.
              On 09/02/2012 at 19:57, xxxxxxxx wrote:
              Thank you for your reply, ScottA.
              I've just solved my problem by omitting the second parameter of the membert  function, GetLink and the code looks like this:
              // SwapPosition.cpp
              switch (id)
              case IDC_OK:
              op1 = (BaseObject* )linkbox1->GetLink(GetActiveDocument());
              if(!op1) return FALSE;
              	op2 = (BaseObject\* )linkbox2->GetLink(GetActiveDocument());
              	if(!op2) return FALSE;
              	break;
              case IDC_CANCEL:
              	break;
              default:
              	break;
