    KeyframeSelection on Bend Deformer?
    6 Posts 0 Posters 664 Views
      On 23/01/2012 at 21:51, xxxxxxxx wrote:
      Can anyone tell me how to set the size description parameter on the bend deformer to be keyframeselection enabled. So it records changes with the record button?
      The simplest attempt:
          size = c4d.DescID(c4d.DEFORMOBJECT_SIZE)
        op.SetKeyframeSelection(size, 1)
      The more advanced attempt
        size = c4d.DescLevel(c4d.DEFORMOBJECT_SIZE, c4d.DA_VECTOR, c4d.Obase)
        id = c4d.DescID(size, c4d.DescLevel(c4d.VECTOR_X, c4d.DA_REAL, c4d.DA_VECTOR))
        op.SetKeyframeSelection(id, True)
        id = c4d.DescID(size, c4d.DescLevel(c4d.VECTOR_Y, c4d.DA_REAL, c4d.DA_VECTOR))
        id = c4d.DescID(size, c4d.DescLevel(c4d.VECTOR_Z, c4d.DA_REAL, c4d.DA_VECTOR))
      My head hurts from banging it on my keyboard.:angry:
        On 24/01/2012 at 02:40, xxxxxxxx wrote:
        The type creator isn't c4d.Obase but c4d.Obasedeform.
        EDIT:
        Well, here's the code I got to make it select Bend's Size attribute and keyframe it:
            size = c4d.DescLevel(c4d.DEFORMOBJECT_SIZE, c4d.DA_VECTOR, c4d.Obasedeform)
            id = c4d.DescID(size)
          On 24/01/2012 at 03:32, xxxxxxxx wrote:
          bit of a mongrel - I think most of this was yours originally Scott
          from c4d import gui
              fps = doc.GetFps()# Gets the frames per second setting
              frame = doc.GetMinTime().GetFrame(fps) #set min time
              doc.SetTime(c4d.BaseTime(frame, fps)) #sets time slider to frame 0
              doc.SetTime(c4d.BaseTime(frame +10, fps)) #sets time slider to frame 10
              c4d.CallCommand(12410) #Execute the Record Button
              op.ClearKeyframeSelection() #Clears the Keyframe Selections
              doc.SetTime(c4d.BaseTime(frame -10, fps)) #sets time slider to frame 0
            Yes, in blue is what I changed to make it work:
              On 24/01/2012 at 07:32, xxxxxxxx wrote:
              Sorry Yannick - I meant Scotts code - as in: Setting the time line etc
              I think that was from one of Scotts Examples
              Thanks for highlighting your change  - useful ref
                On 24/01/2012 at 07:51, xxxxxxxx wrote:
                Thanks guys.
                You saved me some hair pulling today.🍺
