    ID Userdata Q
    2 Posts 0 Posters 318 Views
      On 15/01/2012 at 08:09, xxxxxxxx wrote:
      Started looking at adding and removing user data
      I can see how to add
      and remove
      now if I have this correct
      the remove relies on the number ID
      obj.RemoveUserData([c4d.ID_USERDATA, 1])
      But if a user has already added user data
      the number will not always start at one
      2 Qs:
      1 how do you get that number
      2  how do you track the user data items that you add?
      I've tried getting the number ID_USERDATA but with no luck
      I can only get what I think is referred to as a tuple
      (1,15,0)
      and guessing this is reflects the user data  (numerical index, type, ???)
      thoughts appreciated
      Paul
      add a cube
      add user data
      select cube
      run script
      from c4d import gui
          c4d.CallCommand(13957); # Clear console
          sel_obj = doc.GetActiveObject()
          id_with_bc = sel_obj.GetUserDataContainer()
          for id, bc in sel_obj.GetUserDataContainer() :
              print id, bc, bc[c4d.DESC_NAME], bc[c4d.ID_USERDATA]
          print " "
          print "is this the id", id_with_bc[0][0]
        On 20/01/2012 at 02:51, xxxxxxxx wrote:
        Hi Paul,
        When we call AddUserData(), it returns a DescID (the tuple you are refering to) containing the identification data we can then send to RemoveUserData().
        If the user data has not been added by our code, we can get the DescID by looping trough the user data container with GetUserDataContainer().
        Here is an example showing how to deal with user data DescID, DesLevel, type etc.:
        def AddLongDataType(obj) :
            if obj is None: return
            bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_LONG) # Create default container
            bc[c4d.DESC_NAME] = "Test"                        # Rename the entry
            element = obj.AddUserData(bc)     # Add userdata container
            for i in range(0, element.GetDepth()) :
                print element[i].id                  # element[i] is a DescLevel object
                print element[i].dtype
            # element[0] is for c4d.ID_USERDATA
            # element[1] is for our user data
            print "Added user data : ", element[1].id
            obj[element] = 30                 # Assign a value
            c4d.EventAdd()                    # Update
        def RemoveLongDataType(obj) :
            for element, bc in obj.GetUserDataContainer() :
                if element[1].dtype == c4d.DTYPE_LONG:
                    if obj.RemoveUserData(element) :
                        print "Removed user data : ", element[1].id
                    # To remove the data we could also call:
                    # obj.RemoveUserData(element[1].id)
                    # obj.RemoveUserData([c4d.ID_USERDATA, element[1].id])
            AddLongDataType(op)
            RemoveLongDataType(op)
        Yannick
