    Getting Data from xPresso Nodes
    13 Posts 0 Posters 1.3k Views
      On 13/01/2012 at 13:01, xxxxxxxx wrote:
      One additional question, is there a list or table or something to look up this "GV_DYNAMIC_DATATYPE" relations?
      I cannot find anything about his in the documentation šŸ˜• ...
      Perhaps im just blind ? šŸ˜‰
      The GV data types are documented in the ID_GV_DATA_TYPEs enum.
        On 14/01/2012 at 05:04, xxxxxxxx wrote:
        Thansk Yannick, have a nice weekend!
          On 20/01/2012 at 07:12, xxxxxxxx wrote:
          Hey,Ā
          i got another question šŸ™‚
          Is it also possible to go from an xPresso Node back to the object in the c4d scene the xPresso Node is related to?Ā
          For example something like if i have 3 cubes in my scene i can determine with the xpresso node which cube as a BaseObject im working on with the xPresso Node?
            Yes, retrieving the node's parameter with DescID(GV_OBJECT_OBJECT_ID) as explained in this post.
            In your case you would just call GetParameter() instead.
              On 21/01/2012 at 13:28, xxxxxxxx wrote:
              Hey thanks, šŸ™‚
              i already checked this post out. will let you know if this works! šŸ™‚
                On 07/02/2012 at 06:13, xxxxxxxx wrote:
                Hey Yannick,
                so you meant its done like this:
                GeData data;
                data.SetBaseList2D(pRefObject); <- (expresso node object?)
                pNode->GetParameter(DescID(GV_OBJECT_OBJECT_ID), data, DESCFLAGS_GET_0);
                pNode.... ? -> Whats here to retrieve the node?
                Sorry for asking again but i think documentation is not very helpful here šŸ˜ž
                1. There is no method "SetBaseList2D" existing - nowhere. I checked documentation and source code and api code.
                2. How can i retrieve the node object when i only get an id from the GetParameter method?
                Oukie
                  SetBaseList2D() is new in R13, SetBaseLink() was used before. But in your case you don't need this method; you just want to get the parameter data. It's used to set the data before calling SetParameter().
                  GetParameter() returns a state boolean if it succeed or not. The parameter data is assigned to t_data argument.
                  Here's how to retrieve the node object:
                  node->GetParameter(DescID(GV_OBJECT_OBJECT_ID), data, DESCFLAGS_GET_0);
                  BaseLink* link = data.GetBaseLink();
                  if (link)
                  Ā  Ā  BaseList2D* obj = link->GetLink(doc); // Get node object
                    On 08/02/2012 at 01:33, xxxxxxxx wrote:
                    Thanks a lot Yannick.
                    This works like a charm šŸ˜„
                    Ah thats why i like the maxon guys šŸ˜‰ You are so quick and competent.
                    Cheers.
                    PS: I think there should be a mailer list that notes you when functions like this changed in the api. 😃
                      This is listed for each new release in a "API changes" page in the documentation. šŸ™‚
                        On 08/02/2012 at 01:48, xxxxxxxx wrote:
                        Ah oke than my failure šŸ˜‰ ... Will check this more often.
