    R12 Exporter
    12 Posts 0 Posters 1.1k Views
      On 07/12/2011 at 12:21, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      hello all!
      http://imageshack.us/photo/my-images/689/39340302.jpg
          Object = Document->GetFirstObject();
          GeOutString(Object->GetName(), GEMB_OK);
      There is an error
      How to be run on all objects and will receive their names?
      Forgive for my English, I write through the translator
        On 08/12/2011 at 01:44, xxxxxxxx wrote:
        Here is an example how to iterate through all objects of a document and print their names.
        void WriteObjects(BaseObject *op)
          while (op)
              // do something, for example print name
              GePrint(op->GetName());
              WriteObjects(op->GetDown());
              op=op->GetNext();
        WriteObjects(doc->GetFirstObject());
          On 08/12/2011 at 04:10, xxxxxxxx wrote:
            On 08/12/2011 at 05:51, xxxxxxxx wrote:
            Please start Cinema from the Visual Sudio debugger to see where in your code Cinema is crashing.
            By the way, it is not necessary to pre-allocate a document (m_Document) for BaseDocument::Polygonize.
            Just write something like this:
            BaseDocument *m_Document = NULL;
            m_Document = Doc->Polygonize();
              On 08/12/2011 at 06:28, xxxxxxxx wrote:
                On 08/12/2011 at 06:37, xxxxxxxx wrote:
                Sorry, I can not debug your code for you. This is beyond the scope of the SDK support.
                Just an idea, have you tried to make your WriteObjects function not a class member?
                  On 08/12/2011 at 07:17, xxxxxxxx wrote:
                  In that case I receive
                    On 08/12/2011 at 07:41, xxxxxxxx wrote:
                    Please try in a simple CommandData plugin if you get the same crash.
                      On 08/12/2011 at 10:20, xxxxxxxx wrote:
                      The same situation and with CommandData
                      void WriteObjects(BaseObject* ParentObject)
                        while(ParentObject)
                            WriteObjects(ParentObject->GetDown());
                            ParentObject = ParentObject->GetNext();
                      class CExporter : public CommandData
                        Bool Execute(BaseDocument* Document) {
                            BaseObject* ParentObject = Document->GetFirstObject();
                            WriteObjects(ParentObject);
                            return m_Dialog.Open(DLG_TYPE_ASYNC, ID_DIALOG,-1,-1);
                      private:
                        CDialog m_Dialog;
                      Bool PluginStart()
                        if(!RegisterCommandPlugin(ID_PLUGIN, "MyPlugin", 0, 0L, "Description", gNew CExporter))
                            return FALSE;
                      void PluginEnd()
                      Bool PluginMessage(LONG ID, void* Data)
                        return FALSE;
                        On 09/12/2011 at 06:17, xxxxxxxx wrote:
                        I used quite the same code some days ago and your iteration should definitely work.
                        1. What happens if you remove that dialog stuff?
                        2. Why are you using "CDialog"? Please use "GeDialog" or any of the classes derived from GeDialog.
                          On 09/12/2011 at 06:33, xxxxxxxx wrote:
                          c4dJack
                          #ifndef DIALOG_H
                          #define DIALOG_H
                          #include "preprocessor.h"
                          class CDialog : public GeDialog/*GeModalDialog*/
                           CDialog();
                           virtual ~CDialog();
                            virtual Bool CreateLayout();
                            virtual Bool InitValues();
                            virtual Bool Command(LONG ID, const BaseContainer& Message);
                          #endif
                          CDialog::CDialog()
                          CDialog::~CDialog()
                          Bool CDialog::CreateLayout()
                            this->SetTitle("tool");
                            GroupSpace(50, 50);
                            AddButton(BTN_SAVEMESH, BFH_LEFT, 0, 0, "Save");
                          Bool CDialog::InitValues()
                          Bool CDialog::Command(LONG ID, const BaseContainer& Message)
                            switch(ID)
                                case BTN_SAVEMESH:
                                    BaseDocument* Document = GetActiveDocument();
                                    WriteObjects(ParentObject);  // <----------
                                    StatusSetText("Mesh saved");
                                break;
                            On 09/12/2011 at 07:15, xxxxxxxx wrote:
                            Ah, ok. You derived your CDialog class from GeDialog. That should be ok.
                            Anyway in your last piece of code there was a little error.
                                switch(ID)
                                    case BTN_SAVEMESH:
                                        if (!Document) return FALSE; // <---------- FIX
                                        WriteObjects(Document->GetFirstObject()); // <---------- FIX
                                    break;
