    Differences Standard/Physical Renderer?
    3 Posts 0 Posters 330 Views
      On 30/11/2011 at 04:50, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Platform:      Mac OSX  ;
      Hello again,
      I am just getting a user report about one of my shaders not working with the physical renderer, but rendering just fine with the standard renderer.
      I took a deeper look and it seems to narrow down to a simple IlluminateAnyPoint command:
      Vector CalcIllu3 (VolumeData *sd, LVector *p)
           Bool nodif, nospec;
           RayLight     *lp;
           LONG          i;
           Vector          col,sum=0.0;
           for (i=sd->GetLightCount()-1; i>=0; i--)
                lp = sd->GetLight(i);
                nodif=false;
                nospec=false;
                if (lp->lr.object) CalcRestrictionInc (&lp-;>lr, sd->op, nodif, nospec);
                if (sd->IlluminateAnyPoint (lp, &col;, NULL, *p, ILLUMINATEFLAGS_SHADOW, RAYBIT_CUSTOM) && !nodif) sum += col;
           if (sum.x<0.0) sum.x=0.0;
           if (sum.y<0.0) sum.y=0.0;
           if (sum.z<0.0) sum.z=0.0;
           return sum;
      Any idea what has to be changed? This code is almost 1:1 taken from the SDK.
        On 01/12/2011 at 00:54, xxxxxxxx wrote:
        Could you send us your shader's source code at [email protected] ?
        Regards,
          On 01/12/2011 at 10:26, xxxxxxxx wrote:
          Thank you very much, Yannick.
          I just mailed it to the given address.
