    Shaders- Displace method problem
    3 Posts 0 Posters 329 Views
      On 18/11/2011 at 09:27, xxxxxxxx wrote:
      Cinema 4D Version:   13
      Language(s) :   C.O.F.F.E.E  ;  C++  ;
      Hey guys.
      I'm trying to learn how shaders work. And I'm having trouble with the displace() method.
      Here's my Coffee plugin code:
      var PLUGIN_ID = 1000000;
      class MyVolumeShdr : VolumePlugin
            MyVolumeShdr();
            GetName();
            GetID();
            InitSettings(settings);
            InitRender(settings);
            FillInfoData(settings,is);
            EditData(settings);
            CalcSurface(settings,render,vd);
            Displace(settings, render, vd);
      MyVolumeShdr::MyVolumeShdr()  //Constructor of volume shader
      super();
      MyVolumeShdr::GetName()
      return "My COFFEE Volume Example";  //Name of volume shader
      MyVolumeShdr::GetID()
        return PLUGIN_ID;
      class RenderData
            var col;
            var fbm;
      // Settings=BaseContainer, render=Optional data structure with precalculation data(filled in InitRender), vd = a VolumeData structure
      MyVolumeShdr::CalcSurface(settings,render,vd)
        var diff,spec;                         //Create two vector variables to hold the diffuse, and specular, values
        var p = vd->tdata_im->GetMulP(vd->p);  //Get the inverse texture matrix(tdata) and the global position of each pixel?. And assign it to a variable "p"
        p = p*15;                              //Increase the number of spots
        var renderfbm = render->fbm->Fbm(5,p.x,p.y,p.z)*0.25+0.5;
        vd->Illuminance1(&diff,&spec,5.0);     //Calculate diffuse and specular component for an exponent of 5
        vd->col = vector(diff.x*render->col.x,diff.y*render->col.y,diff.z*render->col.z);  //Calculate surface color and store into 'vd->col'
        vd->col = vd->col * renderfbm + 0.2*spec;                                          //Add the FBM spots on top of the color data
      MyVolumeShdr::InitSettings(settings)
        // 'settings' is a BaseContainer holding settings data
        settings->SetData(1000,vector(0.0,0.0,1.0));  //Set the color to blue...1000 is the container's ID# that holds the color data
      MyVolumeShdr::InitRender(settings)              //Initialize structures for fast rendering
        var rd = new(RenderData);                   //Create an instance of the RenderData class
        if (!rd) return NULL;
        rd->fbm = new(Noise);                       //Create an instance of the FBM noise class
        if (!rd->fbm) return NULL;
        rd->fbm->InitFbm(51.87,1.0);               //Must be called once before Fbm() or RidgedMultifractal() is called. Parameters are(lacunarity, float h)
                                                   //Lacunarity is a measure of how a fractal fills space
        rd->col = settings->GetData(1000);         //Set the color from the IntSettings() method
        return rd;
      CalcFak(p)
        p.x += 222.0;
        p.y +=  24.0;
        p.z += -222.0;
      Displace(settings, render, vd)         //<-------This method is not working!!!
        var i,dv,sam,tcol,col=0.0;
        var p1 = vd->tdata_im->GetMulP(vd->ray->p);
        var p2 = vd->tdata_im->GetMulP(vd->p);
        p1.y = p1.y*0.15+0.5;
        p2.y = p2.y*0.15+0.5;
        dv  = p2 - p1;
        sam = int(8*vlen(dv));
        if (sam<4) sam=4; else if (sam>20) sam=20;
        dv /= sam-1;
        for (i=0; i<sam; i++)
            tcol = CalcFak(p1);
            col += tcol;
            p1  += dv;
        col /= sam;
        if (col>1.0) col=1.0;
        vd->col   = vector(col);
        vd->trans = vector(1.0-col);
      main() // register the VolumeShader 'MyVolumeShdr'
        Register(MyVolumeShdr);
      I will eventually switch to C++ for this shader stuff. But I'm using Coffee&R13 to learn on because I can make changes and update them without closing C4D. And right now I'm learning by changing things and this is the fastest work flow.
      Can anyone tell me why my displace() method doesn't do anything?
      No errors. It simply doesn't produce any result.
        On 18/11/2011 at 13:35, xxxxxxxx wrote:
        First, just a small error; don't forgot to implement Displace() as a member of MyVolumeShdr (MyVolumeShdr::Displace).
        And I found why Displace() wasn't called. By default CalcSurface() is always called. To get Displace() called, we have to override VolumePlugin::GetInfo() and implement it like this:
        MyVolumeShdr::GetInfo(settings)
            return SHADER_DISPLACE;
        And for example, to get also CalcTransparency() called, return SHADER_DISPLACE|SHADER_TRANSPARENCY.
        Have a nice week-end 🙂.
          On 18/11/2011 at 15:23, xxxxxxxx wrote:
          Thanks Yannick.
          I made those changes and it still didn't do anything.
          But then I found this in the docs:`  vd->p += vd->dispn * factor
          When I use that code. In combination with your changes. It works.
          Thanks a lot for the help.
          You have a good weekend too.🍺
