    Make selectbox + Separatorline etc
    3 Posts 0 Posters 301 Views
      On 17/11/2011 at 17:35, xxxxxxxx wrote:
      Cinema 4D Version:   R12
      Language(s) :
      I'm realy confused because i do not find any solution for my Problem. First of all I'm using C# wrapping  it with mono + swig to c++.
      anyways So That's what i got
      DescID cid = new DescID(new DescLevel(SCELETTEOBJECT_TYPE, C4dApi.DTYPE_LONG, 0));
                BaseContainer bcArme = C4dApi.GetCustomDataTypeDefault(C4dApi.DTYPE_LONG);
                bcArme.SetString(C4dApi.DESC_NAME, "Arme");
                bcArme.SetLong(C4dApi.DESC_DEFAULT, 2);
        if (!descparams.Desc.SetParameter(cid, bcArme, new DescID(new DescLevel(C4dApi.ID_OBJECTPROPERTIES))))
                    return true;
      BaseContainer bcArme2 = C4dApi.GetCustomDataTypeDefault(C4dApi.DTYPE_LONG);
                bcArme2.SetString(C4dApi.DESC_NAME, "Finger");
                bcArme2.SetLong(C4dApi.DESC_DEFAULT, 5);
                //bcAuswahl.SetString(C4dApi.DESC_DEFAULT, "st2");
                if (!descparams.Desc.SetParameter(cid, bcArme2, new DescID(new DescLevel(C4dApi.ID_OBJECTPROPERTIES))))
                    return true;
      BaseContainer bcSEP = C4dApi.GetCustomDataTypeDefault(C4dApi.DTYPE_SEPARATOR);
                bcSEP.SetLong(C4dApi.DESC_SEPARATORLINE,C4dApi.DTYPE_SEPARATOR);
       if (!descparams.Desc.SetParameter(cid, bcSEP, new DescID(new DescLevel(C4dApi.ID_OBJECTPROPERTIES))))
                    return true;
      cid = new DescID(new DescLevel(CIRCLEOBJECT_CHECKME, C4dApi.DTYPE_BOOL, 0));
                BaseContainer bcCheck = C4dApi.GetCustomDataTypeDefault(C4dApi.DTYPE_BOOL);
                bcCheck.SetString(C4dApi.DESC_NAME, "Check");
                bcCheck.SetBool(C4dApi.DESC_DEFAULT, true);
                // Create the boolean check box under the previously created sub group (CIRCLEOBJECT_SUBGROUP)
                if (!descparams.Desc.SetParameter(cid, bcCheck, new DescID(new DescLevel(CIRCLEOBJECT_SUBGROUP))))
                    return true;
      I got the following Problems:
      • DESC_DEFAULT has no effect at all e.g. the checkbox, I set it as Defaul true if i open the plugin it's default
      • I do not get the Separator line
      • I Only get the last element @ ID_OBJECTPROPERTIES
      • No clue how to ad a selectbox (Like in the Editor if you Post you can select an Font such a Box I'm trying to accomplish)
      any Ideas?
        On 18/11/2011 at 07:00, xxxxxxxx wrote:
        I get the same behavior. I will investigate more on that.
        Here is how to setup a separator:
        DescID cid = DescID(DescLevel(MY_SEPARATOR,DTYPE_SEPARATOR,0));
        if (!singleid || cid.IsPartOf(*singleid,NULL)) // important to check for speedup c4d!
            BaseContainer bc = GetCustomDataTypeDefault(DTYPE_SEPARATOR);
            bc.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_SEPARATOR);
            bc.SetBool(DESC_SEPARATORLINE, TRUE);
            bc.SetLong(DESC_ANIMATE, DESC_ANIMATE_OFF);
            bc.SetBool(DESC_REMOVEABLE, FALSE);
            bc.SetString(DESC_NAME, "");
            bc.SetString(DESC_SHORT_NAME, "");
            if (!description->SetParameter(cid,bc,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
        If understand, you only get the last parameter added ?
        This is a ComboBox.
        Regards,
          On 18/11/2011 at 08:22, xxxxxxxx wrote:
          First of all thank you I got now the Separator 😉
          Uhm yes i got only the last param but i solved it, I forgot to add for each element a new DescID
          Ok thanks for the hint comboBox I know now what Ive to google for 😉
          Update: OK I got it 😉
          It wasn't ComboBox I had to look for it was CYCLE 😉
          Anways Thank you VERY MUCH again!!!
