    how can I select all polygone objects
    3 Posts 0 Posters 523 Views
      On 08/11/2011 at 00:18, xxxxxxxx wrote:
      Sorry for this noob question
      First: Ihave googled,... read sevear instruction..
      But I'm not a programmner ;-[
      I have to do repeating several changes in a projekt like:
      select all polygon objects
      change to point-mode
      selekt all points
      optimice
      or
      select al polygon objects
      change to polygone-mode
      selekt all polygons
      untriangulate
      or
      select all UV-Tags
      delete all selected Tags
      Now my question:
      Does anybody have an example for selection all polygones.
      The easyest way would be to use the filter in the objekt-manager
      But I don't find a way to execute "select all polygon-objekts"
      Here my code til now:
      from c4d import plugins, utils, bitmaps, gui, documents
          c4d.CallCommand(100004746)       #Aufruf Filter
      But now?
      What is the command for select all polygon-objekts
      and than to select f.e. the UV-Tag
      Thanks a lot
        On 08/11/2011 at 06:28, xxxxxxxx wrote:
        There is no such command, or do you know such a command within Cinema 4D ?
        You need to write it yourself.
        def walk(op) :
          if not op: return
          elif op.GetDown() :
              return op.GetDown()
          while op.GetUp() and not op.GetNext() :
              op = op.GetUp()
          return op.GetNext()
        def selectAllPolygonObjects(doc) :
          op  = doc.GetFirstObject()
          while op:
              if op.CheckType(c4d.Opolygon) :
                  op.SetBit(c4d.BIT_ACTIVE)
                  op.DelBit(c4d.BIT_ACTIVE)
              op  = walk(op)
          On 08/11/2011 at 23:30, xxxxxxxx wrote:
          Hey
          chapoo!!!
          You are the best.
          I posted it in the C4D-Network but I didn't get such a good working solution.
          Thanks a lot!
