    Accessing MoText Group Parameters
    11 Posts 0 Posters 967 Views
      On 03/11/2011 at 19:45, xxxxxxxx wrote:
      Cinema 4D Version:   13
      The Transform parameter IDs under each MoText group (Lines, Words etc) are identical.
      If I want to access e.g. Transform position values under the Lines group, it looks as if I need to use the group ID 'MGTEXTOBJECT_GROUPTRANSFORM_LINE' in conjunction with 'ID_MG_TRANSFORM_POSITION'.
      How do I do this?
        On 05/11/2011 at 14:46, xxxxxxxx wrote:
        Perhaps some more detailed information is needed.
        The Transform tab Scale value for a Cloner can be accessed with:
        BaseContainer *bc = gen->GetDataInstance(); if(!bc) return;
        Vector scale = bc->GetVector(ID_MG_TRANSFORM_SCALE);
        GePrint("scale: " + VectorToString(scale));
        In a MoText, ID_MG_TRANSFORM_SCALE can't be accessed directly as the same ID is used under four different groups.
        Using the Letters group as an example, omograph_text.res has this:
        GROUP MGTEXTOBJECT_GROUPCHAR
             SCALE_V;
             GROUP
                  COLUMNS 2;
                  SCALE_V;
        IN_EXCLUDE     MGTEXTOBJECT_EFFECTORLIST_CHAR
                       SCALE_V;
                       SCALE_H;
                       NUM_FLAGS 1;
                       INIT_STATE 1;
                       IMAGE_01_ON 1018640;
                       IMAGE_01_OFF 1018641;
                       ACCEPT
                            Obaseeffector;
                  STATICTEXT { JOINEND; }
        VECTOR     MGTEXTOBJECT_AXIS_CHAR
                       UNIT     PERCENT;
                       MIN 0.0;
                       MAX 100.0;
                       CUSTOMGUI VECTOR2D;
                  BOOL     MGTEXTOBJECT_AXIS_CHAR_ALIGN
             GROUP MGTEXTOBJECT_GROUPEFFECTOR_CHAR
        MGTEXTOBJECT_GROUPEFFECTOR_CHAR appears to correspond with the Transform parameters. omograph_text.h also lists MGTEXTOBJECT_GROUPTRANSFORM_CHAR. I'm not sure which to use or how many levels are involved.
        I've tried various subcontanier and DescLevel operations to no avail.
        Could someone please provide assistance?
          On 07/11/2011 at 15:00, xxxxxxxx wrote:
          I'd like to bump this because there does seem to be a problem with it.
          The transformation panels inside of the MoText object seem to only be accessible though xpresso.
          C++ example :
          #include "..\..\..\modules\mograph\res\description\otransform_panel.h"
          #include "..\..\..\modules\mograph\res\description\omograph_text.h"
          GeData d;
          obj->GetParameter(DescID(ID_MG_TRANSFORM_SCALE, VECTOR_X), d, (DTYPE_VECTOR, DESCFLAGS_GET_0)); //Result is always zero
          obj->SetParameter(DescID(ID_MG_TRANSFORM_SCALE, VECTOR_X), GeData(5.0), DESCFLAGS_SET_0);       //No errors..But no changes are executed
          Coffee Example :
          var obj = doc->GetActiveObject();      //The MoText object is active
          obj#ID_MG_TRANSFORM_SCALE:VECTOR_X = 1;//Invalid description ID
          Python Example :
            obj = doc.GetActiveObject()                     #The MoText object is active
            obj[c4d.ID_MG_TRANSFORM_SCALE,c4d.VECTOR_X] = 1 #__setitem__ got unexpected type 'int'
          I'm still learning this stuff. So I'm probably wrong about this.
          But It sorta looks like they were never added to the API's?
            On 08/11/2011 at 01:30, xxxxxxxx wrote:
            Thanks for taking the time to do some testing Scott.
            The problem with using ID_MG_TRANSFORM_SCALE in this way is that the same ID is used for independent parameters under the All, Lines, Words and Letters groups. A higher-level ID from omograph_text.h has to also be used.
              On 08/11/2011 at 07:45, xxxxxxxx wrote:
              Did you figure it out David?
              I did also try using higher ID's in a bunch of different ways. But I still couldn't get it to work.
              example:
              obj->SetParameter(DescID(MGTEXTOBJECT_GROUPLINE, ID_MG_TRANSFORM_SCALE,VECTOR_X), GeData(15.0), DESCFLAGS_SET_0); //Does not work
                On 09/11/2011 at 03:53, xxxxxxxx wrote:
                No, unfortunately I don't have a solution Scott.
                Apparently neither do any of the other developers here or Maxon support.
                  On 09/11/2011 at 06:08, xxxxxxxx wrote:
                  Sorry for the delay. I asked the developers and will post the solution if there is one.
                    On 09/11/2011 at 14:19, xxxxxxxx wrote:
                    Thanks Matthias. At least I know I'm not missing something obvious.
                      On 10/11/2011 at 06:38, xxxxxxxx wrote:
                      You need to use the following group offset to obtain the final ID.
                      MGTEXTOBJECT_GROUPTRANSFORM_ALL
                      MGTEXTOBJECT_GROUPTRANSFORM_WORD
                      Simply add transform ID and group offset ID for the final ID.
                      Example:
                      GeData d;
                      if (op->GetParameter(DescLevel(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE),d,DESCFLAGS_GET_0))
                        GePrint(RealToString(d.GetVector().x));
                        On 10/11/2011 at 07:48, xxxxxxxx wrote:
                        Thanks Matthias.
                        Sorry for being so dense. But I still can't get the SetParameter() to work with your example:
                        obj->SetParameter(DescID(ID_MG_TRANSFORM_POSITION, VECTOR_X + MGTEXTOBJECT_GROUPTRANSFORM_LINE), GeData(0.3), DESCFLAGS_SET_0); //Does not change
                        And what about the scripting languages?
                        This plus sign thing doesn't seem to work with them for me either.
                        *Edit- I managed to figure out a way to get it to work:
                            BaseObject *obj = doc->GetActiveObject(); //The MoText object is active
                          GeData d; //A variable to hold the parameters
                          if (obj->GetParameter(DescLevel(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE),d,DESCFLAGS_GET_0))
                               GePrint(RealToString(d.GetVector().x));  //Print the x Position value
                               Vector newV = Vector(5,0,0);             //Create a new vector position value
                               d.SetVector(newV);                       //Set the vector parameter held in variable d to this new vector value in memory only
                               obj->SetParameter(DescID(ID_MG_TRANSFORM_POSITION + MGTEXTOBJECT_GROUPTRANSFORM_LINE), GeData(newV), DESCFLAGS_SET_0); //Execute the vector change from memory
                               GePrint(RealToString(d.GetVector().x));  //Print the new x Position value
                        Still trying to figure out how to use this with Coffee & Python.
                          On 11/11/2011 at 05:00, xxxxxxxx wrote:
                          Works like a charm, thanks again Matthias.
