    Current State To Object in Python
    3 Posts 0 Posters 617 Views
      On 30/10/2011 at 09:15, xxxxxxxx wrote:
      Hey there!
      Bit stuck on how to execute this in order to bake something with a mograph displacer on it into geometry.
      Here's what I've got thus far. It mentions something in the docs about potentially needing to act on a duplicate of the object but then doesn't really elaborate. Any help much appreciated!
      Cheers, sCam
      from c4d import gui
      from c4d import utils
      from c4d import documents
          document = documents.GetActiveDocument()
          settings = c4d.BaseContainer()
          obj = document.SearchObject("picture source")
          return_value = utils.SendModelingCommand(
               command = c4d.MCOMMAND_CURRENTSTATETOOBJECT,
               list = [obj],
               mode=c4d.MODELINGCOMMANDMODE_ALL,
               bc=settings,
               doc = document)
          print return_value
        On 30/10/2011 at 12:10, xxxxxxxx wrote:
        Hi, I assume this is a standard script and not part of a Python Generator, correct?
        The code you posted works fine. Just insert the returned object in the document and update it:
        from c4d import gui
                 list = [obj],
                 bc=settings,
                 doc = document)
            #NEW----
            if return_value:
                doc.InsertObject(return_value[0]) #return_value is a list in this case
            #NEW----
          On 01/11/2011 at 00:26, xxxxxxxx wrote:
          Worked great! Thanks for your help - much appreciated!
          Cheers, sCam
