    Texture change python
    5 Posts 0 Posters 829 Views
      On 26/10/2011 at 08:54, xxxxxxxx wrote:
      Hi there,
      Is there a way to change the texture in the color channel of a material using python.
      Currently i'm writing a script where there is a variable on my clipboard wich is used to build up a document.
      If my question isn't clear, let me know.
      Much thanx in advance.
      Kind regards RNE
      Script so far:
      from c4d import gui, bitmaps, documents
      c4d.StopAllThreads()
      c4d.StatusSetSpin()
      c4d.StatusSetText("Starting script")
      datanaam = c4d.GetStringFromClipboard()
      c4d.CallCommand(1024314) # Clear Python Log
      c4d.CallCommand(1022604) # Open Python Log
      klaar maken om te renderen
      rd = doc.GetActiveRenderData()
      instellen van de rendersettings op basis van de texture
      c4d.StatusSetText("Adjusting render settings")
      currpath=''+rd.GetDataInstance()[c4d.RDATA_MULTIPASS_FILENAME]
      currpath=''+doc[c4d.DOCUMENT_PATH]+'/'
      rd[c4d.RDATA_MULTIPASS_SAVEIMAGE] = 1 # 1=aan 0=uit
      rd[c4d.RDATA_MULTIPASS_FILENAME] = r''+currpath+"Renders/"+datanaam+'.psd'
      #changing the texure
      #save the current document as a c4d file
      c4d.documents.SaveDocument(doc, currpath+"CinemaFiles/"+datanaam+".c4d", c4d.SAVEDOCUMENTFLAGS_DIALOGSALLOWED, c4d.FORMAT_C4DEXPORT)
      lijst=c4d.documents.GetBatchRender()
      lijst.AddFile(currpath+"CinemaFiles/"+datanaam+".c4d",0)
      c4d.documents.BatchRender.Open(lijst)
      c4d.StatusSetText("Added to renderlist")
      c4d.documents.CloseAllDocuments()
      c4d.CallCommand(465003513); # start render queue
        On 26/10/2011 at 18:07, xxxxxxxx wrote:
        The thought process is as follows:
        -Get the material you want to change by whatever means you prefer(if Active, It's name, etc.).
        -Create a new Xbitmap shader to hold your texture image.
        -Tell that Xbitmap shader where to find the texture image using file paths.
        -Insert that Xbitmap shader into the color channel of the material.
        This example will insert the image named "myimage.jpg" from your desktop into the color channel of the currently active material:
        import os
          fn = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
          pathToTexture = os.path.join(fn,'myimage.jpg')      #Gets the specific texture image on your desktop
          mat = doc.GetActiveMaterial()                       #Assign the active material a variable
          shdr_texture = c4d.BaseList2D(c4d.Xbitmap)          #Create a bitmap shader in memory
          shdr_texture[c4d.BITMAPSHADER_FILENAME] = pathToTexture #Assign the path to the texture image to your shader
          mat[c4d.MATERIAL_COLOR_SHADER]= shdr_texture        #Assign the shader to the color channel in memory only
          mat.InsertShader(shdr_texture)                      #Insert the shader into the color channel
          mat.Update(True, True)                              #Re-calculate the thumbnails of the material
          On 27/10/2011 at 01:50, xxxxxxxx wrote:
          Big thanx ScottA
          Now I can't find any documentation on how to select a material by its name.
          Can you please help me out. mat = doc.GetMaterial doesn't work ?
          Kind regards RNE
            On 27/10/2011 at 03:13, xxxxxxxx wrote:
            To get a material by name, there is doc.SearchMaterial(name).
              On 28/10/2011 at 04:22, xxxxxxxx wrote:
              Thanx a lot, this works great.
