    Update MultipassBitmap
    3 Posts 0 Posters 328 Views
      On 18/10/2011 at 00:44, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hy there,
      I want to set floating-point values to an allocated MultipassBitmap. I find it strange, that there is no method to set floating-point values, I can just see `
      Bool SetPixel(LONG x, LONG y, LONG r, LONG g, LONG b);
      `from the BaseBitmap class.
      After a while of searching I then figured out, that I could maybe use the GetLine and SetLine if casted to a VPBuffer. Now I use the example code from the invert-image example to read a line into a buffer and set the buffer back.
      When I set it back, it always returns FALSE, so the SetLine is not working. For testing purpose I didn't change the buffer that I read out, but that doesn't change the outcome. I do all this within a TagData plugin's message-callback method.
      What can I do?
      Is there another method I can use to update a MultipassBitmap with Real values?
      Is it possible, to write data to a Bitmap residing in a Bitmap shader?
      Thank you,
      maxx
        On 19/10/2011 at 02:58, xxxxxxxx wrote:
        Here is a simple example how to create and access a 32bit floating point MultipassBitmap:
        Bool MenuTest::Execute(BaseDocument *doc)
          MultipassBitmap *mbmp = NULL;
          SReal *buffer = NULL;
          mbmp = MultipassBitmap::Alloc(512, 512, COLORMODE_RGBf);
          if (!mbmp) goto Error;
          buffer = GeAllocType(SReal, 512*3);
          if (!buffer) goto Error;
          //fill a line; I used a brightness over 100% (4.0)
          for (LONG i=0; i<512*3; i++)
              buffer[i] = 4.0;
          //cast the SReal buffer into UCHAR; inc parameter is 3*4bytes (3*32bit) because of floating point image format
          for (LONG y=0; y<512; y++)
              if (!mbmp->SetPixelCnt(0, y, 512, (UCHAR* )buffer, 12, COLORMODE_RGBf, PIXELCNT_0)) goto Error;
          ShowBitmap(mbmp);
          MultipassBitmap::Free(mbmp);
          GeFree(buffer);
        Error:
          GeFree(buffer);
          return FALSE;
        Unfortunatly not.
          On 19/10/2011 at 09:18, xxxxxxxx wrote:
          Thanks a lot for the example!
          maxx
