    Make a toggle-button with image on in GeDialog
    11 Posts 0 Posters 1.7k Views
      On 05/10/2011 at 13:26, xxxxxxxx wrote:
      I'm not sure if you can do this in R12. Because SetImage() was not supported yet.
      But it does work in R13.
      Here's a complete dialog plugin example:
      import c4d, os, sys
      from c4d import plugins, utils, bitmaps, gui, documents
      Plugin_ID=1000009 # Testing id ONLY!!!!!!!
      #enums
      myBitButton = 100010
      class MyDialog_Gui(gui.GeDialog) :
       def CreateLayout(self) :
        bc = c4d.BaseContainer() #Create a new container to store the image we will load for the button later on
        self.GroupBegin(0, c4d.BFH_SCALEFIT|c4d.BFH_SCALEFIT, 1, 1, "Bitmap Example",0) #id, flags, columns, rows, grouptext, groupflags
        self.GroupBorder(c4d.BORDER_BLACK)
        bc.SetLong(c4d.BITMAPBUTTON_BORDER, c4d.BORDER_OUT) #Sets the border to look like a button
        bc.SetBool(c4d.BITMAPBUTTON_BUTTON, True)
        fn = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
        path = os.path.join(fn,'image1.jpg')                #The path to the image file
        bc.SetFilename(100010, path)                        #Fill the empty container with the id#, and the image's location(string value)
       #Lets check our container to see if the image's ID# and location are now stored in it properly
        image = bc.GetData(100010)
        print image
        for i in bc:
          print i
        self.myBitButton=self.AddCustomGui(100010, c4d.CUSTOMGUI_BITMAPBUTTON, "Bitmap Button", c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT, 30, 30, bc)
        self.myBitButton.SetImage(path, False)
        self.LayoutChanged(10042) #Updates the custom gizmo changes made to the GUI
        self.GroupEnd()
       def InitValues(self) :
      self.SetString(4002,"Waiting") #Sets the text inside of the field when the plugin opens
      self.SetString(4003,"Waiting") #Sets the text inside of the field when the plugin opens
      self.SetReal(1002, 0, 0,100,1) #Sets the slider's value to 0... With a range of 0-100... Step=1
       def Command(self, id, msg) :
      if id == 100010:
          print"Bitmap Button was Pushed"
          self.myBitButton.SetToggleState(True)
          fn2 = c4d.storage.GeGetC4DPath(c4d.C4D_PATH_DESKTOP) #Gets the desktop path
          path = os.path.join(fn2,'image2.jpg')                #The path to the image file
          self.myBitButton.SetImage(fn2, False)                #This does not work like in C++ !!!
      #   MyDialog_Main --- Where the plugin stuff happens--Don't edit
      class myDialog_Main(plugins.CommandData) :
       dialog = None
       def Execute(self, doc) :
        # create the dialog
        if self.dialog is None:
           self.dialog = MyDialog_Gui()
        return self.dialog.Open(dlgtype=c4d.DLG_TYPE_ASYNC, pluginid=Plugin_ID, defaultw=200, defaulth=150, xpos=-1, ypos=-1)
       def RestoreLayout(self, sec_ref) :
        # manage nonmodal dialog
        return self.dialog.Restore(pluginid=Plugin_ID, secret=sec_ref)
       path, fn = os.path.split(__file__)
       bmp = bitmaps.BaseBitmap()
       bmp.InitWith(os.path.join(path, "res/icons/", "None"))
       plugins.RegisterCommandPlugin(Plugin_ID, "myPythonDialog",0,None,"", myDialog_Main())
      Make sure you change the image references to image files you have on your desktop.
      Or change the paths to where you want them to look for the button images.
      As you can see. One thing I'm having trouble with is swapping  the button's image when it's clicked.
      This works perfectly in C++. But I can't get it to work with Python in R13.
        On 09/10/2011 at 07:42, xxxxxxxx wrote:
        I really don't understand why you always create ids but not use them..
        Unfortunately this code does not work does only work in R13. Why not use a GeUserArea ? There it is also easy to swap the images.
        See this example code.
          On 09/10/2011 at 08:47, xxxxxxxx wrote:
          Unfortunately this code does not work in R13.
          Other than the image swapping part. It works just fine for me.
            On 09/10/2011 at 08:59, xxxxxxxx wrote:
            Oh 😂
            I meant R12, sorry 😉
              On 09/10/2011 at 09:13, xxxxxxxx wrote:
              You had me worried there for moment.🙂
              I was thinking about posting a UA example too. But the guy was asking for help with SetImage() & GetIcon() functions. So I didn't think he wanted to use a UA.
              I'd still like to know why my images don't swap using those functions like it does in C++.
                On 28/10/2011 at 07:15, xxxxxxxx wrote:
                ScottA: hum... SetToggleState([True/False]) dont give me any visual feedback at all it looks like the button is stuck even if the event is triggered. In the new R13 documentation there is now a mentioning of BITMAPBUTTON_ICONID1 and BITMAPBUTTON_ICONID2 but I don't get my head around how they should be used or if they would help in your example.
                Nux95: even if GeUserArea is not a button and it is a lot of extra code to setup... but it does work!
                Tnx!
                  On 28/10/2011 at 09:19, xxxxxxxx wrote:
                  It's hard to say for sure because the documentation is so limited on this subject.
                  But it looks like a bug.
                  The reason I say it's a bug is twofold:
                  1- It works properly in C++
                  2- self.myBitButton.SetToggleState(False) & self.myBitButton.SetToggleState(True) both return: None
                    On 28/02/2012 at 08:36, xxxxxxxx wrote:
                    Hi every 1 just jioned here yesterday and just started python copied and pasted the code you put up Scotta but im getting this error code can you give me any tips why the error is on this line of code
                    it says
                    NameError:name'_file_'is not defined
                    cheers.
                    Ray.
                      On 28/02/2012 at 08:37, xxxxxxxx wrote:
                      The code is not for the script-manager, put it into a *.pyp file and save it in Cinema 4D's plugin-folder.
                        On 28/02/2012 at 08:40, xxxxxxxx wrote:
                        Cheers bud much great help.
                         Ray.
