    SOLVED: Why can't I add simple renderdata?
    2 Posts 0 Posters 413 Views
      On 15/09/2011 at 17:17, xxxxxxxx wrote:
      I am making a simple script that does the following
      1. Runs through a simple loop that iterates different scene cameras (controlled with User data ID:17)
      2. Changes the Renderoutput path (c4d.RDATA_PATH) based upon this loop
      3. Renders the image with this filename.
      I am able to get steps 1 and 3 working fine. However 2 doesnt update in the render settings. The c4d.RDATA_PATH function won't actually write the change to the render setting. Is there a better method for approching this problem. I thought that there would be a render function that had a path argument, rather than getting it from the render setting.
      I know this is somthing really simple, but i cant seem to find out what i am doing wrong guys.
      from c4d import bitmaps, documents
      c4d.CallCommand(1024314) # Clear Python Log
      c4d.CallCommand(1022604) # Open Python Log
      def PreviewLoop() :
        doc          = documents.GetActiveDocument()
        rd           = doc.GetActiveRenderData().GetData()
        for i in xrange(5) :
            rd[c4d.RDATA_PATH] = r'C:	emp0' + str(i+1) #Iterate Render Path
            op[c4d.ID_USERDATA, 17] = i+4 #Iterate Seleceted Camera
            print str(rd[c4d.RDATA_PATH]) # Preview path Confirmation
            bmp = bitmaps.BaseBitmap()
            bmp.Init(x=1024, y=576, depth=32) #Initiate Render Resolution
            documents.RenderDocument(doc, rd, bmp, c4d.RENDERFLAGS_EXTERNAL)
            bitmaps.ShowBitmap(bmp) #Launch Picture Viewer
      PreviewLoop()
      print 'Done!'
      Any ideas? thanks.
        On 15/09/2011 at 18:34, xxxxxxxx wrote:
        Looks like i solved it 🙂
        Had something to do with     rd           = doc.GetActiveRenderData(). I  moved the GetData() to the documents.RenderDocument argument...
        Here is the updated code.
        def PreviewLoop() :
          op[c4d.ID_USERDATA, 14] = 0 # Disable any Analaglyph Preview settings
          print 'Rendering Preview...' # Preview Confirmation.
              rd[c4d.RDATA_PATH] = r'C:\ViewX	emp0' + str(i+1) #Iterate Render Path
              documents.RenderDocument(doc, rd.GetData(), bmp, c4d.RENDERFLAGS_EXTERNAL)
        PreviewLoop()
        print 'Done!'
