    R13 Python Script Reload
    3 Posts 0 Posters 496 Views
      On 12/09/2011 at 03:08, xxxxxxxx wrote:
      I think there is a little poor effect in R13 new function of python script reload. Existings sockets and threats will not reseted. Or is there an event available on which a plugin can do it itself if the plugin will be unload?
      Meinolf
        On 12/09/2011 at 06:02, xxxxxxxx wrote:
        Hi, the documentation will be available soon. The reload stuff must be done by the plugin, this cannot be solved by the reload command. In your main file add the following lines and shutdown all the services:
        def PluginMessage(id, data) :
          if id==c4d.C4DPL_RELOADPYTHONPLUGINS:
              ShutdownAllYourStuff() #shutdown all services, sockets, listener, ...
          return False
        If you have have a socket server you can also handle C4DPL_ENDACTIVITY to shutdown the services properly when C4D is closed.
        Cheers, Sebastian
          On 13/09/2011 at 10:04, xxxxxxxx wrote:
          Thx! Tongue
          Meinolf
