    HPBToMatrix and R13?
    6 Posts 0 Posters 902 Views
      On 09/09/2011 at 05:33, xxxxxxxx wrote:
      where are the definitions of "order" in R13 for methode HPBToMatrix??
      _<_dt id="c4d.utils.hpbtomatrix"_>_ c4d.utils.HPBToMatrix( hpb , order )
      e.g. utils.HPBToMatrix(myhpb,c4d. ROT_YXZGLOBAL) will result in "module object has no attribute 'ROT_YXZGLOBAL'.
      And if I set direct numeric values from R12, the effect in R13 is not the same as in R12:
      eg.: utils.HPBToMatrix(myhpb,0 _)
      Has anybody an idea?
      Meinolf
      _
        On 09/09/2011 at 07:23, xxxxxxxx wrote:
        I can only confirm that it does not work as before.
        We do need SDK snippets asap for this and the new SplineGUI.
        Lennart
          On 09/09/2011 at 08:35, xxxxxxxx wrote:
          It looks like the new definitions are found in the coffee.h file.
          EXAMPLE:
          c4d.utils.HPBToMatrix(myhpb, c4d.ROTATIONORDER_ZXYGLOBAL)
            On 09/09/2011 at 08:50, xxxxxxxx wrote:
            Ah, good call.
            Interesting how the rotations are based from the vector….
            v.x = pitch
            v.y = heading etc…
            Lennart
              On 09/09/2011 at 09:35, xxxxxxxx wrote:
              Jepp, this is fine. Thank you! Now my plugin works well with R13.
              To keep scripts compatible with R12 we now have to make extra code:
                    if (c4d.GetC4DVersion()>=13000) :
                        c4dROT_HPB=c4d.ROTATIONORDER_HPB
                        c4dROT_YXZGLOBAL=c4d.ROTATIONORDER_YXZGLOBAL
                        c4dROT_HPB=c4d.ROT_HPB
                        c4dROT_YXZGLOBAL=c4d.ROT_YXZGLOBAL
              ...and we have to exchange first and second component of the vector... 😠
                                v=c4d.Vector(cmd['y'],cmd['x'],cmd['z'])
                                v=c4d.Vector(cmd['x'],cmd['y'],cmd['z'])
              Meinolf
                On 09/09/2011 at 16:09, xxxxxxxx wrote:
                It looks as if:
                HPBToMatrix(vector) still can be used (only 1 argument)
                Is this a legacy mode that will be dropped at a time later?
                Also, are we sure the "swapped" x and y vectors are correct and not a bug?
                PS.
                R12 GetOptimalAngle(vectorA , vectorB)
                is changed.
                It now need a 3:rd argument, rotation order to run (no legacy mode)
                R13 is:
                GetOptimalAngle(vectorA , vectorB, c4d.ROTATIONORDER_XYZGLOBAL)
                I haven't checked if the vectors are swapped as in the HPBToMatrix()
                DS.
