    Fontchooser
    8 Posts 0 Posters 822 Views
      On 08/09/2011 at 02:14, xxxxxxxx wrote:
      Cinema 4D Version:   13
      hello,
      I'm using the Fontchooser (FONT ID {} ) in a res file of my plugin. And now I like to read the font name which the user choosen (to print out in an xml file). How can I do this.
      I know in the last versions it doesn't works with the FontData class !
      thanks
      Marky
        On 12/09/2011 at 05:54, xxxxxxxx wrote:
        With R13 you can now access the font container. The GeClipMap class provides font access functions (I know not the first place to look for).
        Here is a small example how to initialize and read out a font description. MY_FONT is just a FONT description in the resource files. I initialize with the "Arial" font as example. If not found it will use the default system font instead.
        Bool LookAtCamera::Init(GeListNode *node)
          BaseContainer *data=((BaseList2D* )node)->GetDataInstance();
          if (!data) return FALSE;
          GeData d(FONTCHOOSER_DATA, DEFAULTVALUE);
          FontData* fd = (FontData* )d.GetCustomDataType(FONTCHOOSER_DATA);
          if (!fd) return FALSE;
          BaseContainer bc;
          GeClipMap::EnumerateFonts(&bc, GE_CM_FONTSORT_FLAT);
          LONG i=0;
          while (TRUE)
              LONG id = bc.GetIndexId(i++);
              if (id==NOTOK) break;
              BaseContainer *fbc = bc.GetContainerInstance(id);
              if (fbc)
                  String name;
                  if (!GeClipMap::GetFontName(fbc, GE_FONT_NAME_DISPLAY, &name)) return FALSE;
                  if (name.Compare("Arial") == 0)
                      fd->SetFont(fbc);
                      if (!data->SetData(MY_FONT,d)->GetType()) return FALSE;
          BaseContainer bc2;
          if (!GeClipMap::GetDefaultFont(GE_FONT_DEFAULT_SYSTEM, &bc2)) return FALSE;
          fd->SetFont(&bc2);
        EXECUTIONRESULT LookAtCamera::Execute(BaseTag *tag, BaseDocument *doc, BaseObject *op, BaseThread *bt, LONG priority, EXECUTIONFLAGS flags)
          GeData d;
          if (tag->GetParameter(DescLevel(MY_FONT),d,DESCFLAGS_GET_0))
              FontData *fd = (FontData* )d.GetCustomDataType(FONTCHOOSER_DATA);
              if (fd)
                  BaseContainer bc = fd->GetFont();
                  String name;
                  if (GeClipMap::GetFontName(&bc, GE_FONT_NAME_DISPLAY, &name))
                      GePrint(name);
          return EXECUTIONRESULT_OK;
        EDIT: corrected the initialization code
          On 13/09/2011 at 02:24, xxxxxxxx wrote:
          hello Matthias,
          thanks for this example. But unfortunately I get always a DA_NIL value for the GeData
          in my Init() function.
          Do you know why ?
          regards
          Marky
            On 13/09/2011 at 03:58, xxxxxxxx wrote:
            Indeed there is a problem. I will look into it.
              On 13/09/2011 at 04:43, xxxxxxxx wrote:
              Ok, I corrected the Init() routine. As example I intialize it with the "Arial" font. If not found it will use the default system font instead.
                On 13/09/2011 at 05:41, xxxxxxxx wrote:
                fine, that's working now.
                My last question, how can I set a font in a osplinetext object?
                BaseObject* text = BaseObject::Alloc(Osplinetext);
                GeData data;
                BaseContainer *bc = text->GetDataInstance();
                data.SetString(op->GetDataInstance()->GetString(TXT_ID_PAINTSPLINETEXT_TEXT,""));
                bc->SetParameter( DescLevel(PRIM_TEXT_TEXT), data);
                bc->SetParameter( DescLevel(PRIM_TEXT_FONT), ?????
                regards
                Marky
                  On 13/09/2011 at 06:41, xxxxxxxx wrote:
                  You set it the same as I did in the Init() routine just with the PRIM_TEXT_FONT parameter ID.
                    On 13/09/2011 at 07:13, xxxxxxxx wrote:
                    super, it works. thanks a lot
