    i3DMouse - Turn your iPhone into a 3D mouse!
    4 Posts 0 Posters 705 Views
      On 25/08/2011 at 21:06, xxxxxxxx wrote:
      Today my first iPhone app is released in Apple's AppStore. It's a 3D Mouse. The communication with C4D was created with a Python script. This script makes the connection via an UPD socket and REST.
      So, Python and C4D are fine! It's fast enough to handle real time inputs via an UDP socket.😄
      You will find more information and a demonstration video at http://www.dongleware.com/i3dmouse.php
      Regards, Meinolf
        On 25/08/2011 at 22:41, xxxxxxxx wrote:
        I'm really really curious about how you've done the communication between Python and the iPhone. But I don't think your gonna show source code, do you ?
          On 26/08/2011 at 02:48, xxxxxxxx wrote:
          The part of the script which implements a threaded UDP communication is very simple and based on chapter 20.17.4.3 of this documentation: http://docs.python.org/library/socketserver.html
          To use an UDP connection instead of a TCP connection you have just change
          server = ThreadedTCPServer((HOST, PORT), ThreadedTCPRequestHandler)
          to
          server=UDPServer(("0.0.0.0",UDPPort),UDPHandler)
          and e.g.
          class UDPHandler(SocketServer.BaseRequestHandler) :
            def handle(self) :
              data=self.request[0].strip()
              print "%s wrote:" % self.client_address[0]
              print data
              cmd=json.loads(data)
              if cmd['action']=="camMove":
          So the plugin gets the asynchronous packages in methode **UDPHandler::handle** from where you can handle the json string.
          Very simple.
          Meinolf
            On 08/09/2011 at 02:07, xxxxxxxx wrote:
            Never done sth. with networking. Interesting, thank you ! 😉
