    GetActiveTag
    3 Posts 0 Posters 336 Views
      On 16/08/2011 at 00:40, xxxxxxxx wrote:
      Cinema 4D Version:   12
      Hello, its me again. I am Stucked with my Smoothedge-Script. I want to restrict a Splinedeformer to the current Pointselection of the selected Object. With my code I have the Problem that it does not work if there is already a Selection-Tag on the Object.
      I tried to use GetActiveObject(). But the functions does not exist aparently.
      Do you know how I can get the exact Selection tag, that is created with the Set Selection-Command?
      Here is what I have:
      obj->GetActiveObject();
      CallCommand(12139); // Points
      CallCommand(12552); // Set Selection
      var selectiontag = obj->GetFirstTag();
      while(selectiontag->GetType()!=5674) // As long as it's not a selection tag.
      selectiontag=selectiontag->GetNext(); // Get the next tag until it finds one that's a selection tag
      selectiontag#ID_BASELIST_NAME="smoothedge-restriction";
      var restag = AllocTag(5683);//restiction Tag
      splineDeformer->InsertTag(restag);//Apply tag
      restag#RESTRICTIONTAG_NAME_01="smoothedge-restriction";
        On 16/08/2011 at 05:38, xxxxxxxx wrote:
        doc->GetActiveObject();
        You might also want to use a for loop as you will crash readily with that while() loop:
        ------------------------------------------- ends loop if tags exhausted
        for (selectiontag = obj->GetFirstTag(); selectiontag; selectiontag = selectiontag->GetNext())
        if (selectiontag->GetType == 5674) { do you stuff here; break; }
          On 16/08/2011 at 06:15, xxxxxxxx wrote:
          Thank you Robert,
          nice Idea.
