    User Data Integer Opions?
    7 Posts 0 Posters 687 Views
      On 13/08/2011 at 08:02, xxxxxxxx wrote:
      Cinema 4D Version:   9.6+
      Howdy,
      How can I get to the options of an Integer User Data through code?:
      Adios,
      Cactus Dan
        On 13/08/2011 at 08:08, xxxxxxxx wrote:
        Hi, with C4DAtom::GetDynamicDescription you can browse through the userdata of an object. With DynamicDescription::Browse* and the retrieved BaseContainer you can access all these values. Cheers, Sebastian
          On 13/08/2011 at 08:17, xxxxxxxx wrote:
          Howdy,
          Thanks Sebastian, but which container am I looking for that will be the "Options"?
          That's probably how I should have worded the question. 😊
          Adios,
          Cactus Dan
            On 13/08/2011 at 08:35, xxxxxxxx wrote:
            Howdy,
            DOH!  The container is "DESC_CYCLE"!
            Hehe, I should've known that. 😊
            Adios,
            Cactus Dan
              On 13/08/2011 at 15:18, xxxxxxxx wrote:
              Howdy,
              OK, I can create a User Data popup menu, and I can detect if an object has a popup menu with this code:
              Bool TestCommand::Execute(BaseDocument *doc)
              	BaseObject *op = doc->GetActiveObject();
              	if(op)
              		DynamicDescription *dd = op->GetDynamicDescription();
              		if(dd)
              			DescID dscID;
              			const BaseContainer *bc;
              			void *dscHnd = dd->BrowseInit();
              			while(dd->BrowseGetNext(dscHnd, &dscID, &bc))
              				GeData gData;
              				CDGetParameter(op,dscID,gData);
              				if(bc->GetLong(DESC_CUSTOMGUI) == CUSTOMGUI_LONG)
              					BaseContainer *cycle = bc->GetContainerInstance(DESC_CYCLE);
              					if(!cycle) GePrint(bc->GetString(DESC_NAME)+" - No DESC_CYCLE detected");
              					else
              						GePrint(bc->GetString(DESC_NAME)+" - DESC_CYCLE detected");
              			dd->BrowseFree(dscHnd);
              	EventAdd(EVENT_FORCEREDRAW);
              But, how would I get the number of entries that are in the popup menu?
              I'm not only interested in the current value of the popup menu User Data, but I'd also like to know how many items are available in the popup menu.
              Adios,
              Cactus Dan
                On 17/08/2011 at 02:11, xxxxxxxx wrote:
                I think you need to manually count the entries in the DESC_CYCLE container.
                  On 18/08/2011 at 08:48, xxxxxxxx wrote:
                  Howdy,
                  Thanks, Matthias. That worked. 😉
                  Adios,
                  Cactus Dan
